Go to Post Cooperate BEHIND the curtain; compete IN FRONT OF it. - Travis Hoffman [more]
Unread 11-01-2013, 18:58
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Air Compressor help!
If you hook up the compressor according to the FIRST documentation, the compressor will automatically shutoff at a safe pressure. You can adjust some of the valves to make it so this will not happen - although I do not know why you would want to do that.
Programming wise (LabView) I believe there is an example program, and if not search the LabView forums here for your answer. It has been asked many times. When I get into the shop tonight I might have time to post some code.
Evan
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
