Go to Post How many robotics kids does it take to turn on a light? - demosthenes2k8 [more]
Go Back   Chief Delphi > Competition > FRC Game Design
Unread 11-01-2013, 18:53
CAPTIN_CAPSLOCK CAPTIN_CAPSLOCK is offline
Head Scout of FRC Team 1339
AKA: Christian
FRC #1339 (AngelBotics)
Team Role: Scout
CAPTIN_CAPSLOCK is an unknown quantity at this point
Question What are the competition pyramid dimensions?
There are several discrepancies between the pyramid designs given to the FIRST Teams and the actual competiton pyramids. I would like to know what the competition pyramids dimensions are, so that my team can build a pyramid that will be beneficial for practice.
Unread 11-01-2013, 18:55
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: What are the competition pyramid dimensions?
Q. There seems to be discrepancy between the Autodesk CAD model and drawings of the pyramid (pulled from the game arena file). Specifically, the drawings show that the rungs (1,2,3) are all 30” apart in the vertical, and at a consistent 68 degrees from horizontal. The CAD model shows that the first two rungs (1,2) are also 30” apart in the vertical, and 68 degrees from horizontal, but the inconsistency is in the third rung. The third rung is depicted higher than 30” - not at the joint of the 68 degree angled bar and the vertical section of the pyramid - but several inches above on the vertical bar. This changes the angle and climbing plans. Has anyone else seen this, or does anyone have a concrete source that we can trust to design around? Thanks –
A. Per Section 2.1, the FIELD drawings published by FIRST are the official source for all dimensions.
Published by GDC
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 11-01-2013, 18:57
AKA: Christian
Team Role: Scout
Thumbs up Re: What are the competition pyramid dimensions?
Published by GDC
Thank you.
Unread 11-01-2013, 19:00
AKA: Christian
Team Role: Scout
Question Re: What are the competition pyramid dimensions?
Published by GDC
Do you know of any other discrepancy? I think it would be a good idea for to compile a list and post it to Chief Delphi so that the other teams have practice fields that will properly prepare them for the competition.
Unread 14-01-2013, 00:02
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Published by GDC
The Autodesk model is incorrect. FIRST has been made aware of this, along with the fact that there is no declarative statement to indicate that the models are in error (particularly important since the models are linked to from the FIRST team resources pages, lending an impression of credibility). Teams should not be using the models to design against until corrections are made. Hopefully, this will be done soon.
-dave
