Go to Post What if, each alliance has a pile of AndyMark equipment in front of them. They then have 2:00 minutes to assemble said equipment, and build a working robot that will race to the other side and grab the other alliance's flag. - Pjohn1959 [more]
Unread 11-01-2013, 19:13
Ganondalf Ganondalf is offline
FRC #4665
Ganondalf is an unknown quantity at this point
Re: Air Compressor help!
Originally Posted by Wiifi View Post
If you hook up the compressor according to the FIRST documentation, the compressor will automatically shutoff at a safe pressure. You can adjust some of the valves to make it so this will not happen - although I do not know why you would want to do that.
Programming wise (LabView) I believe there is an example program, and if not search the LabView forums here for your answer. It has been asked many times. When I get into the shop tonight I might have time to post some code.
Evan
Thank you very much for your help, I really appreciate it!
