Go to Post We try to do cool stuff (note: I didn't say it always works). - marshall [more]
Unread 11-01-2013, 13:44
duffany1 duffany1 is offline
AKA: Brandon
FRC #0195 (The Cyberknights)
duffany1 is an unknown quantity at this point
DAP 1522 Rev B - Power Light is Red
Yesterday we attempted to wire up the DAP 1522 Rev B. We hooked it up exactly how it says to in WPI's website. The problem is that when we power on the robot, the "power" light on the wireless bridge is blue for about a quarter of a second, then immediately turns red, and the radio does not function. We tested the voltage output to the radio and it seems to be about 4.9 - 5.3 volts.
Any ideas as to what the problem could be?
Might it be that we have a defective radio? If so, can we use an old radio for now? How do you deal with a defective product being in the KoP?
Unread 11-01-2013, 13:49
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: DAP 1522 Rev B - Power Light is Red
how is the radio being powered? Is it powered from the regulated output, through the DC-DC converter?
2016: Lake Superior WFFA
Unread 11-01-2013, 14:10
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
You can use an old radio for now (if you know how to set it up, but you may have the same exact problem). There is a process for managing defective KoP parts, but the deadline may have passed for that. Go to the FIRST website, FRC, and Kit Of Parts Home for more information.
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 11-01-2013, 14:26
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Based on your description, it doesn't sound as though you have the radio polarity reversed, but check it just to be sure.
If you have a defective part, the deadline is Sunday to report it. Any radio will work for testing, you only need the exact model D-Link on the field.
Unread 11-01-2013, 19:23
Fifthparallel Fifthparallel is offline
AKA: Sam Chen
FRC #1410
Fifthparallel is an unknown quantity at this point
Just confirming that we had the same problem earlier, but our 1522reb is stuck in bridge mode now.
sudo chmod u+x helloworld.sh
gotta start somewhere.
Unread 12-01-2013, 12:19
Mr.Trips Mr.Trips is offline
FRC #3179
Mr.Trips is an unknown quantity at this point
Duffany1 my team 3179 is also experiencing the same exact problem and i don't believe its from a defected part. For we have tried several of our Ds and we get the same exact result.
Unread 12-01-2013, 17:38
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Originally Posted by Mr.Trips View Post
The power light for the D-Link will light up to a light blue for about one second, then the power light will turn red. We have the D-Link is set to "AP 2.4 GHz" mode.
You may want to contact DLink support to address this problem. Alternatively, you can go through the replacement parts process.
@Sam and Mr.Trips, is your power supply wired per the directions that Brandon (duffany1) linked to?
Another possibility: Have you updated to firmware rev 2.03?
What problems do you encounter trying to operate the DAP when its power light is red?
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 12-01-2013, 17:49
AKA: Brandon
Guys, we solved the problem. We plugged the bridge into a computer (not the cRIO) and configured it with the new 2013 bridge configuration tool. (We also inserted the disc labeled "Start Here," though we're not sure if that actually did anything.)
Thanks!
Unread 12-01-2013, 19:11
AKA: Sam Chen
FRC #1410
We were using the plug-in-the-wall that came with the box.
