Go to Post Truly listening to the wealth of advice around you is so important. Don't work in a vacuum all season long. - OZ_341 [more]
Unread 10-01-2013, 22:24
TheChosen1 TheChosen1 is offline
Software Wizard
FRC #2840
TheChosen1 is an unknown quantity at this point
Wind River has no FIRST tab
Ok, so I have installed WindRiver with no evident problems during the installation, but after I apply the 2013 workbench update, and proceed to run WindRiver for the first time, I have no FIRST tab from which I may deploy or undeploy code. This is obviously a major problem for our team and I was wondering if anyone else has experienced this and/or knows how to fix it. I have found a few similar threads on the forums but none of them seemed to have helped me in my predicament. The tutorial that I followed may be found here: http://wpilib.screenstepslive.com/s/...s#!prettyPhoto
I am running WindRiver 3.3.1, if it helps.
Unread 11-01-2013, 19:31
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Wind River has no FIRST tab
Just to be sure, are you saying there is no FIRST item in the menubar in Workbench after installing the update? Also, can you confirm that you've installed Workbench into C:\WindRiver? The update assumes that installation path.
Brad
Brad Miller
Robotics Resource Center
Unread 13-01-2013, 16:05
Software Wizard
FRC #2840
Sorry about the late reply, in any case, I actually managed to fix it and the fix is an odd one, in my case I could only get the FIRST tab to appear when I installed WindRiver without the second install disc, the reason why this is so odd is because I am, in fact, using a 64 bit machine on windows 7, which is what the second install disc is for.
Unread 13-01-2013, 19:59
nightpool's Avatar
nightpool nightpool is offline
robotRectifier
AKA: Evan
no team (formerly of CORE 2062)
nightpool is on a distinguished road
Are you sure? I installed WindRiver on a 64-bit Windows 8, and I used the second disk. It all seems fine... Did you run the patch AFTER the second disk?
Proud alum of CORE 2062.
www.core2062.com
Unread 15-01-2013, 21:54
Software Wizard
FRC #2840
I'm sure I did, I know it's very weird, but what can I say, at least it is fixed.
