Go to Post It's a FIRST thing. You gots to understand. - Koko Ed [more]
Unread 08-01-2013, 00:35
rl1806's Avatar
rl1806 rl1806 is offline
AKA: Ryan Lowe
FRC #1806 (S.W.A.T.)
rl1806 will become famous soon enough
Clarification of pyramid rung height
Is the height of the rungs on the pyramid measured from the top of the rung or the center of the rung?
Section 2.2.5 of the game manual specifies the height of the rungs but not what part of the rung is at that height. Our fabrication team has looked at the field drawings but is still trying to figure this out.
2011-Present: SWAT FRC 1806 Mentor
2012 Rockwell Automation Innovation in Control Award [Oklahoma City]
Unread 08-01-2013, 09:43
MentorPrice's Avatar
MentorPrice MentorPrice is offline
Mentor/FIRST Alumni/Engineer
AKA: Kevin Price
FRC #1708 (Amp'D Robotics)
MentorPrice is an unknown quantity at this point
Re: Clarification of pyramid rung height
More than likely it is at the center of the rung because the rung is made out of 1 1/2" diameter pipe I think. I would refer to the offical usfirst forum.
Team #1708 Drive Team & Member (2006-2008)
Team #4547 Westmont Hilltoppers Mentor (2013-2014)
Team #1708 McKeesport Amp'D Robotics Mentor (2009-2012, Current)
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.”
Nikola Tesla
“A Machine to End War” (Liberty, February, 1935)
Unread 10-01-2013, 10:56
rl1806's Avatar
AKA: Ryan Lowe
The response from the FIRST Q&A system was
Please refer to Figure 2-7 and tolerances in Section 2.1 and FIELD assembly drawings.
2-7 and some of the assembly drawings look like they are measuring the rung height from the center of the rung.
Unread 10-01-2013, 11:15
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
My shoddy math skills applied to the field assembly drawings shows it to be about 30" at the top of the rung, relative to the tops of the four base plates, which are....how thick? a quarter inch?
This promises to be fun, folks!
Unread 11-01-2013, 17:28
rl1806's Avatar
AKA: Ryan Lowe
The plate that sits directly on the floor (GE-13025-01), in Game Specific Drawings, is .12” thick. The leg of the pyramid mounts to the bracket (GE-13025-02) on top of the plate is 1.25” high. Did you measure the height of the rungs from the top of the plate on the floor or from where the leg mounts to the bracket?
One of the students on our team found an Inventor model of the pyramid showing the rungs at 30,60,90” on center but the height of the pyramid and some of the other dimensions were off from what the manual says. I will have to post a picture of the drawing later.
Unread 11-01-2013, 21:39
rl1806's Avatar
AKA: Ryan Lowe
The inventor model shows the first two rungs at the correct height measured from the center of the rung but level 3 is short putting the entire pyramid 6.47” too short.
Unread 11-01-2013, 23:28
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Isn't that because the base of the pyramid is too short? Shouldn't it be 94"?
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 12-01-2013, 12:34
rl1806's Avatar
AKA: Ryan Lowe
I downloaded another model from the Autodesk FIRST site and it was different from the drawing I posted earlier. The height was correct but the width of the base was narrower than the last model.
Our team just sat down and looked at all the drawing, figure 2-7, and the Inventor models and came up with the following dimensions. The Rungs are at 30”, 60”, and 90” measured to the center line of the pipe, the width of the base is 94” as specified in the manual, and we calculated the other dimensions based on the field drawings.
