Go to Post Free hugs are excellent things. - Eugenia Gabrielov [more]
Unread 11-01-2013, 23:38
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: Software control or gearing
I believe RobotIn3Days did something like that, but basically what the issue was that without a controller, the first wheel slowed down quite a bit first, so a second wheel was used to boost the muzzle velocity. Having the first wheel move slower would theoretically allow more overhead for a controller to work to improve the performance, but then again using the proper controller for a shooter wheel would improve the performance without the need for a second wheel.
Alternatively, without a controller, you could simply use the slower wheel to gradually speed up the wheel, so you might be able to shove more shots through.
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
