Go to Post I was not looking at this as a backdoor to asking Brandon to do it (when I have impossible/unreasonable tasks I want done, I ask him straight out ;-) - Joe Johnson [more]
Unread 11-01-2013, 22:47
Camren's Avatar
Camren Camren is offline
FRC #3081 (RoBoEaGleS)
Camren is a jewel in the roughCamren is a jewel in the roughCamren is a jewel in the rough
Prototype data
Hello chief delphi community,
Tonight we got the testing finished on our shooting prototype. its the half circle design. I have published the data here;
DATA
please take a look at the comments for some notes on the data
Thanks
-C
Unread 11-01-2013, 23:34
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: Prototype data
There's not a whole lot of data, but it's some good data.
What exactly is Vertical Spread Up and how is that different from Vertical Spread Down? Same for the left/right designation.
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 11-01-2013, 23:45
GBilletdeaux930's Avatar
GBilletdeaux930 GBilletdeaux930 is offline
AKA: Greg
FRC #0930 (Mukwonago Bears)
GBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to all
Re: Prototype data
If I were to guess, it'd be the deviation between all the shots from the mean?
What I'm seeing, is that the rubber wheel at the higher rpm was the only one that's variation was small enough to fit within the top goal every time.
Unread 12-01-2013, 00:14
AKA: Nathan Hui
Re: Prototype data
Also what would be nice is to see pics of the prototype used, so that we have an understanding of the exact conditions of the experiment.
Nathan Hui
FTC 4950, 6038
Unread 12-01-2013, 00:17
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Prototype data
http://www.youtube.com/watch?v=ThZCOtjVJmw for a video of our shooter.
Enlarge the picture by clicking on it. You can see the different results via different colored markers or an "X" on the tape.
An X indicates 8inch rubber w/ rubber tread (plaction)
Black (lower left) indicates 8inch rubber w/ rubber tread (plaction)
Blue (lower right) indicates 8 inch Pnuematic
Image showing the results
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 12-01-2013, 00:20
AKA: Nathan Hui
Re: Prototype data
All I have to say is... okay...
Could you explain the numbering?
Nathan Hui
FTC 4950, 6038
Unread 12-01-2013, 00:22
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Re: Prototype data
I edited my previous post with that info. Should be above the image. I am about 99% sure that the info is correct. I was in the other half of the room while this was going on.
Unread 12-01-2013, 00:28
AKA: Nathan Hui
Re: Prototype data
The spread's going the wrong way (it's 90 degrees to the ideal spread, which is a landscape oriented rectangle). I'm wondering if the feed was done by a machine, would the spread go down? Also, did the one dimple on the wheel make a difference (i.e. would a better made wheel have improved performance by a significant amount)?
Also, I hope these refrigerator targets weren't used in that hall with that trajectory - that would invalidate the entire data set.
Nathan Hui
FTC 4950, 6038
Unread 12-01-2013, 00:32
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Re: Prototype data
We'll have to check out some of those questions tomorrow!
We had the test set up much like it looks in this video. (not in the hallway) http://www.youtube.com/watch?v=iHElJFyGW6Y
Unread 12-01-2013, 00:46
Camren's Avatar
Re: Prototype data
Alright the all in on answering post
The test set up was a fridge set up 24' 9" away from the fixed shoot roughly at 35 degrees from the table that was standing up about 2 feet from the ground.
Spread was determined based off of an point of best fit. then from the point we measure out to the farthest up, down, left and right hit.
Why is there not higher rpm pneumatic wheel test: First reason the wheel in my opinion one wasn't balanced and two didn't have the right fit to the bead, causing lots of vibration and for safety reasons we cut it off at 3500 rpm. Secondly we were happy with the accuracy of pneumatic wheel at 3500 rpm. the 80 rpm test on the treaded wheel came about after an odd spread at 3500 rpm.
In addition to Evans posts above the 12" and 0" circled were benchmarks to see how it would fly into the 3 point goal.
Unread 12-01-2013, 00:49
AKA: Nathan Hui
Re: Prototype data
Hmm. Humans downrange of the shooter. Cannon fodder much?
Now that I think about it, try clamping the shooter to a table and weighing the table down as much as possible so that the shooter doesn't jerk around.
Nathan Hui
FTC 4950, 6038
Unread 12-01-2013, 00:51
Camren's Avatar
Re: Prototype data
All member down range of the Frisbee launcher have Ultimate Frisbee training. Do not try at home.....
Unread 12-01-2013, 19:31
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Prototype data
OMG that poor Fridge!
Unread 12-01-2013, 21:56
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Re: Prototype data
Not as bad as what we did today.... We put tape all over the entire thing to calculate velocity of the frisbees. Needed a way to trigger limit switches! I will have more data to post on the velocity come Monday.
Unread 13-01-2013, 00:20
Camren's Avatar
Re: Prototype data
We were losing too many rookies to injury. so we picked the fridge for target practice
