Go to Post "We put the eek in Geek" - Wayne Doenges [more]
Unread 11-01-2013, 18:42
Ganondalf Ganondalf is offline
FRC #4665
Ganondalf is an unknown quantity at this point
Question Air Compressor help!
Hello,
Would anybody be able to provide me with an example on how to make an air compressor continuously run? The compressor is hooked up to a spike/relay switch. Thank you!
Or even, how to hook up a compressor to a button.
(Below I've provided a screen shot of my vi's, does everything look alright?)
Allons-y!
Unread 11-01-2013, 18:58
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Air Compressor help!
If you hook up the compressor according to the FIRST documentation, the compressor will automatically shutoff at a safe pressure. You can adjust some of the valves to make it so this will not happen - although I do not know why you would want to do that.
Programming wise (LabView) I believe there is an example program, and if not search the LabView forums here for your answer. It has been asked many times. When I get into the shop tonight I might have time to post some code.
Evan
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 11-01-2013, 19:13
FRC #4665
Evan
Thank you very much for your help, I really appreciate it!
Unread 12-01-2013, 00:14
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Feel free to pm me with any specific questions.
Unread 12-01-2013, 01:14
FRC #4665
So this is what I have so far... do I need to make any changes or does everything look alright? All I want the compressor to do is turn on and remain on.
Unread 12-01-2013, 01:23
Wildcats1378 Wildcats1378 is offline
Wildcats1378 is an unknown quantity at this point
If you have got it all hooked up right, that should work. The digital modules are unnecessary to, uh, put though. It will work with just the pressure switch DIO channel and the relay channel.
Unread 12-01-2013, 01:26
FRC #4665
Excellent! Finally getting somewhere with this compressor haha
Unread 12-01-2013, 19:23
FRC #4665
It worked!
