Go to Post Just put it in the dryer for a few extra cycles. That should shrink it down nice and small. - notmattlythgoe [more]
Unread 12-01-2013, 01:02
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Bumper Design
Every year we put off making bumpers to the last week of the season, slapping them together before we get to the competition, sometimes stapling them on the bus. Furthermore, they often aren't well integrated into the frame and take a long time to change between matches. We don't really like bumper covers as they tend to look rather poor.
I was wondering how other teams deal with creating bumpers that are easy to take on and off between matches and stay on sturdily during them. Specifically I'm looking for mounting hardware that others may have worked with that is good. Usually we use wing nuts and bolts which are quite finicky.
Thanks in advance!
Unread 12-01-2013, 01:16
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: Bumper Design
We put C-shaped brackets on the back, sized to fit neatly over the frame rails with no slack. We drill a vertical hole all the way through each bracket and rail. Then we put a clevis pin or hitch pin through to lock it and latch the pin so it doesn't fall out if the robot is inverted or takes an upward hit to the bumpers. Solid connection, rapid installation and removal (as long as we put each bumper assembly on the correct side for the holes to line up).
Unread 12-01-2013, 01:27
greyandwhite greyandwhite is offline
FRC #3482
greyandwhite is an unknown quantity at this point
Re: Bumper Design
Last year we designed our bumpers to be held in place by bolts fastened by some quick release pins,https://encrypted-tbn2.gstatic.com/i...kQsVL_cfhEVPyg
something like that, and we were able to change them pretty quickly once we got the hang of it..
Unread 12-01-2013, 04:03
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: Bumper Design
People have suggested quarter turn fasteners before, similar to the fasteners used in race cars.
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 12-01-2013, 07:39
dk5sm5luigi's Avatar
dk5sm5luigi dk5sm5luigi is offline
AKA: Nick Galotti
FRC #1735 (Green Reapers)
dk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud of
Send a message via AIM to dk5sm5luigi
Re: Bumper Design
We essentially permanently mount our bumpers (we can take them off if needed). Instead of switching them we have it so we sow the fabric so we can just flip it over. It takes seconds and looks much better than a cover.
Team 1735 Green Reapers: 2005-Present
Team 190 Gompei: 2001-2005
Team 155 Technonuts: 1997-2001
http://www.first-a-holics.com/
http://www.findrobotparts.com/
Unread 12-01-2013, 08:24
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Re: Bumper Design
^ can you post a pic, I am not following the concept. Thanks
We also use the C channel on the back, over a 1" frame rail, then a pin with a clasp that you would see on tractor implements.
The sooner we get behind schedule, the more time we have to catch up.
Unread 12-01-2013, 08:28
ptkunapuli478 ptkunapuli478 is offline
FRC #0341 (Miss Daisy)
Team Role: CAD
ptkunapuli478 is an unknown quantity at this point
Re: Bumper Design
I believe we do the same essentially
Team 341 Miss Daisy
Pranav Kunapuli
Captain
CAD
Unread 22-01-2013, 19:47
WeRrobots WeRrobots is offline
FRC #4125
WeRrobots is an unknown quantity at this point
Re: Bumper Design
Our team has been thinking on how to do something similar; however, we're not entirely sure on how to go about it. Is there any way you could post a picture, or a diagram of how your flip design for your bumper works?
Unread 22-01-2013, 19:58
mikemat mikemat is offline
mikemat has a spectacular aura aboutmikemat has a spectacular aura aboutmikemat has a spectacular aura about
Re: Bumper Design
I believe this is what they're talking about.
Unread 22-01-2013, 20:15
Duncan Macdonald's Avatar
Duncan Macdonald Duncan Macdonald is offline
Globe Motor Fan Club
FRC #0610 (Crescent Robotics)
Duncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond repute
Send a message via MSN to Duncan Macdonald
Re: Bumper Design
K-Botics 2809 Reversible Bumpers White Paper
My unbiased opinion would be to start here
Queen's Applied Science '13, Applied Mathematics
Unread 23-01-2013, 19:57
hf3132 hf3132 is offline
AKA: Hannes F.
FRC #3132
hf3132 is an unknown quantity at this point
Re: Bumper Design
Something that also works rather well is to have connected bumper sections connected via a hinge.
For example, on our 2012 off season robot, we had a cutout in the front of the C-Frame, to pick up the balls. our bumpers were in two parts, each covering one long side, one short bit at the front of the robot and half of the back.
The connections between them were hinged. That enabled us to bend the outer two pieces of the bumper out a bit more, making it far easier (and less frustrating ) to put on.
Unread 23-01-2013, 21:18
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Bumper Design
Hinges can be tricky, as far as inspection goes. in 2008, we used hinges to hold our smallest pieces on (WAY less than 8", back then it was legal), and it took some convincing that they were mounting hardware. It would have hurt to redesign the bumper mount in the pits.
I'd like to get inspector opinions on hinged bumpers. (To be absolutely clear, not Articulating bumpers, just bumpers connected together at the hinge to make them easier to fold around the robot.)
Unread 24-01-2013, 03:22
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Bumper Design
The first thing to watch out for is whether those hinges may be counted as part of the bumper, part of the main robot itself, and/or a separate thing. (The rule refers to "any fasteners and/or structures that attach [bumpers] to the ROBOT".) The rules are ambiguous on this point, but I'd tend to give a team the benefit of the doubt if they interpreted the rule in either of the first two ways.1 Confusingly, "removable fasteners" are explicitly part of the bumpers.
A related issue is whether the bumpers are part of the robot—this is complicated and annoying because of the different senses of the word robot, but once again, given the ambiguity, I'd give the team the benefit of any reasonable interpretation.
The current rules call for "a rigid fastening system to form a tight, robust connection to the main structure/frame [of the robot]". Many sets of hinges could satisfy this, installed correctly. It doesn't have to be a specific type of mounting hardware anymore (threaded fasteners were once specified).
With regard to bumper articulation, I interpret that as meaning that to pass inspection, and when on the field, articulation must be prevented. However, I reject the notion that bumper articulation (e.g. via hinges) during assembly of the robot is prohibited. (By definition, every robot is illegal when you're not finished installing the bumpers.)
1 If you rule it legal as part of the robot or bumper, it counts toward that assembly's weight and size. Inspectors often need latitude to rule it one or the other on a case-by-case basis, to avoid frame perimeter and bumper hard part surgery.
Unread 24-01-2013, 07:39
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
Re: Bumper Design
Originally Posted by Tristan Lall View Post
[snip]
[snip]
[snip]
That's just it. Since they attach bumpers to other bumpers, it could be argued that they are not "fasteners and/or structures that attach [bumpers] to the ROBOT"
I like them for keeping the bumpers together in more complicated bumper setups. I haven't used them as such since 2008, though.
Unread 24-01-2013, 07:56
Re: Bumper Design
Using hinges to hold bumper sections together at a corner is an acceptable method and the hinges and pins must be weighed with the bumper. Using this type of hardware keeps adjacent sections together especially if you are only using the minimum bumper sections at the corners of your robot.
