Go to Post I'm a programmer by training and inclination, so my mechanical ideas are sometimes rather, um, loosely constrained by physical reality. - Alan Anderson [more]
Unread 01-07-2013, 10:34 PM
Hypnotoad's Avatar
Hypnotoad Hypnotoad is offline
Junior Assistant Secretary of Moon
Hypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these parts
Image display to smartDashboard.
Hello. I am trying to get an image with the bounding box of my target onto the smartDashboard. The one problem I have run into is that I have no idea of how to get modified images over to the computer. The only way I have found to get a camera onto the smartDashboard was with view> add> camera. I was just wondering if there was any existing code to do so. I don't mind writing my own widget as it would be a good learning experience but I would NOT like to rewrite software that already exists just for the sake of learning, as 6 weeks is not much time.
The following sentence is true.
The preceding sentence is false.
This sentence is false.
This signature is false.
My teeth are false.
Unread 01-08-2013, 11:53 AM
AsianRookie AsianRookie is offline
AKA: Steven/Tim
FRC #0321 (Robolancers)
AsianRookie is an unknown quantity at this point
Re: Image display to smartDashboard.
Do you need an image from the camera to image process?
Unread 01-08-2013, 12:09 PM
shank948 shank948 is offline
VP of Programming - 948
AKA: Stephen Shank
FRC #0948 (NRG (Newport Robotics Group))
shank948 is an unknown quantity at this point
Have you looked into Roborealm? This resource was distributed in the KOP this year, with a link to the download and a license key. I haven't done much work with it myself, but my understanding is that it will help you do exactly what you are trying to do.
If it's green and slimy, it's Biology.
If it smells, it's Chemistry.
If it doesn't work, it's Physics.
- My Physics Teacher
Fixed:
If it doesn't work, it's our Robot up until that last few days of the build season.
Unread 01-08-2013, 03:36 PM
Hypnotoad's Avatar
Honestly, I checked it out and using it would be more complicated and difficult, for us at least. We already have an image and all of the things we need to draw the rectangle. We just need to draw it and get it to the smartDashoard. So do I have confirmation that I will have to write my own widget.
My teeth are false.
Unread 01-10-2013, 09:19 PM
timothyb89 timothyb89 is offline
code monkey
FRC #1977 (Loveland High Robotics)
timothyb89 will become famous soon enough
We did this last year, we modified the SquareTrackerExtension from the smartdashboard svn repository to have it draw polygons recognized by our vision code: source
The usual image processing additions are in processImage() (which did the bounding boxes) and then the UI additions are in paintComponent(). The additions were mainly some debug text and the ability to click and select polygons for the targeting system.
I'm a bit unfamiliar with the the 2013 vision code, but if it's at all similar this could help out a bit.
FRC-DB: A detailed, web-based scouting database for FRC teams with lots of interesting statistics.
Unread 01-12-2013, 10:07 AM
Hypnotoad's Avatar
I started a new thread about this but I'm going to ask it here as I have not gotten any replies on said thread. Does anyone have GOOD documentation on how network tables works? The java docs don't count. I mean like a PDF.
My teeth are false.
