Go to Post Fire and smoke are great if you're into Battlebots, but we like to avoid them in FIRST competitions. - [more]
Unread 19-01-2003, 14:17
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
fcvt and itoa differences?
I posted earlier about problems using MessageBox (windows.h) with dynamic input from fcvt (string.h) and I found the problem. It seems that itoa requires the address of a character array while fcvt uses a character pointer. My question is: why? Aren't these two things theoretically the same other than a predefined amount of memory for the array?:
char *string1,string2[10];
string1="test";
string2="test";
The way I am looking at it, these should be the same. If this is the case, why does fcvt require string1 while itoa/ltoa requires string2?
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 19-01-2003, 14:34
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
The way fcvt works is that it returns a pointer to a static variable inside its function, much like strtok. Therefore, the memory is already allocated and all you have to do is point to it. Thus, you use a char *. Also note that calling fcvt again will overwrite whatever was returned previously. Therefore, you should immediately do a strcpy(localString, stringFromFcvt) so that you don't loose the data.
itoa, on the other hand, probably does the strcpy for you, meaning that the buffer needs to already be allocated and large enough to accept the string.
Other random fcvt notes: Remember that fcvt will not insert a decimal point in the string for you. The location of this decimal point is returned as the third parameter to the function. Same with the sign, which is returned as the fourth.
Unread 19-01-2003, 15:23
That makes sense. Kind of annoying that two very similar functions have such a different syntax... This Direct3D is giving me so much trouble.. My new problem is that it won't calculate my vertex normals correctly! Instead of placing normals for each triangle on a face, it seems to do a few triangles in the array only... arg...
Unread 19-01-2003, 16:22
Zmeko Zmeko is offline
Zmeko is an unknown quantity at this point
ITOA code from the CRT:
PHP Code:
static void __cdecl xtoa (
unsigned long val,
char *buf,
unsigned radix,
int is_neg
char *p;                /* pointer to traverse string */
char *firstdig;         /* pointer to first digit */
char temp;              /* temp char */
unsigned digval;        /* value of digit */
buf;
        if (
is_neg) {
/* negative, so output '-' and negate */
*p++ = '-';
val = (unsigned long)(-(long)val);
firstdig p;           /* save pointer to first digit */
do {
digval = (unsigned) (val radix);
val /= radix;       /* get next digit */
            /* convert to ascii and store */
if (digval 9)
p++ = (char) (digval 10 'a');  /* a letter */
else
p++ = (char) (digval '0');       /* a digit */
} while (val 0);
/* We now have the digit of the number in the buffer, but in reverse
           order.  Thus we reverse them now. */
*p-- = '\0';            /* terminate string; p points to last digit */
do {
temp = *p;
= *firstdig;
firstdig temp;   /* swap *p and *firstdig */
--p;
firstdig;         /* advance to next two digits */
} while (firstdig p); /* repeat until halfway */
http://www.cplusplus.com/ref/cstdlib/fcvt.html
itoa cant convert a double to a string, fcvt can.
Anyways, Adam Shapiro, visit http://www.cplusplus.com/ref/. it contains information about functions in the standard c library and iostream.
i think in the future they might cover STL but you can always visit the STL docs for information: http://www.sgi.com/tech/stl/stl_index.html
Unread 19-01-2003, 17:09
That was actually the first place I checked for the info. Their info helped but I was still a bit confused. I think I understand now though.
