Go to Post Who cares about having a boyfriend when I have my robot? - Jaine Perotti [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 09-01-2013, 20:57
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
80/20 Channel
Does anyone know of a piece that would fit into 2 pieces of 80/20 channel (the x-shaped kind with grooves) that would allow the 2 pieces to slide while the edges stay joined to eachother? I know that bolt-heads work, but I was wondering if they had a piece designed for this that would reduce friction.
Thank you!
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 09-01-2013, 20:58
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: 80/20 Channel
Are you trying to make a linear slider out of 80/20?
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 09-01-2013, 21:01
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: 80/20 Channel
Talk to team 357 if you're trying to make linear slides. They made a cast and molded their own plastic slides for 80/20. It was in the 2007 "Behind the Design" book.
GitHub
Unread 09-01-2013, 21:12
Anyun Anyun is offline
Co-Captain Team 1308
FRC #1308 (Wildcats)
Anyun is an unknown quantity at this point
Re: 80/20 Channel
Two years (Logomotion) ago our initial placement mechanism for the inflatable pieces used a linear slider (we scrapped it later in favor of a pneumatic arm). Anyways, we did it by using brackets and a pulley system. The brackets were used to make sure the channels didn't go to far up and fall, and the channels were just slid on to each other. The pulley would force the channels to slide along each other until they hit the bracket above them, then the next piece would start rising.
It wasn't very effective for us, and I doubt it will work well, but it's a starting point if you're desperate.
Unread 09-01-2013, 21:16
AKA: Cam Pizzo
Re: 80/20 Channel
Yes, we are trying to make a linear slide out of it, but it is a little more complex than that. It won't be large, but we will definitely need something as robust as 80/20. We have very limited machining capabilities, so anything COTS would be great.
Unread 09-01-2013, 21:20
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Re: 80/20 Channel
So... 80/20 linear slides..?
http://www.8020.net/Solution-8.asp
AKA yes they have tons of linear slide components for sale.
They're just VERY expensive.
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 09-01-2013, 21:40
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
MrRiedemanJACC will become famous soon enough
Re: 80/20 Channel
They are expensive, but we have worked with our local 80/20 salesperson for sometime and if you need small quantities (couple of feet) they may just be able to help you out. Our local salesperson has been more than reasonable in the past.
Unread 09-01-2013, 23:33
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: 80/20 Channel
Back in the day, 1403 used bushing tubing to do a similar thing....
http://www.chiefdelphi.com/media/photos/20128
the tubes shown actually have different ODs, and then we had a bushing slider (mcmaster calls them sleeve bearings) inbetween.
Not such a teaser anymore?
Unread 10-01-2013, 00:18
Donut Donut is online now
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: 80/20 Channel
We built an extending elevator in 2005 that used the linear slides and the roller guides, they work really well as long as you space them far enough apart (we sometimes drove our rollers too close together and caused the elevator to bind). By far our highest scoring robot and we used some of them again in 2007 with success. If I remember correctly we just got the bearing pads and mounted them ourselves, not the full assemblies or bearing profiles, which saves some on cost.
Bosch also has some linear elements for use with their extrusion that is similar to 80/20: http://www13.boschrexroth-us.com/Fra...aspx?Group=112. I think the profiles are different enough that the sliders aren't interchangeable with 80/20 but don't take my word on it. It looks like they make linear bushings like 1403 used as well.
Igus makes nice linear slide elements, my senior design project used one of their slides on it. They're a long time sponsor of FIRST (how I found about them), most teams probably know them for including energy chain for cable routing in the kit every year but they actually do a lot with plastic bearings and even included a few linear parts in FIRST Choice this year. They're out of stock in FIRST Choice now but you can get a 1 meter guide rail and a sliding carriage for it for about $100.
Unread 10-01-2013, 01:36
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
Re: 80/20 Channel
also sold as linear bearings
http://www.amazon.com/s/ref=nb_sb_no...linear+bearing
mcmaster's link to them doesn't seem to work right
My Instructables
Unread 10-01-2013, 02:03
ThaneS ThaneS is offline
FRC #0167 (Children of the Corn)
ThaneS is an unknown quantity at this point
Re: 80/20 Channel
I would recommend looking though McMaster-Carr's (http://www.mcmaster.com/) selection of linear rail components. Just search for "Linear Rail". They have a great selection. It may not be the cheapest in the world, but it will save you a lot of searching.
P/N 60585K18 are specifically made for sliding along 80/20. I am somewhat weary of any sleeve bearing solution though, as they are often much easier to bind. However, ball bearing slides are usually more expensive. If you call/e-mail McMaster, they may be able to give you values for the maximum moments that can be placed on the carriages. That should give you an idea of how resistant to binding the carriage will be.
Unread 10-01-2013, 07:45
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Re: 80/20 Channel
Yes, 80/20 has some excellent linear slide concepts.
The three sided bearings are pricey, but the flat plate slides are more affordable.
This hard to find item is very,very useful for the 1" size framing. (Fastenal Part# 0961342 -- 80/20 Part#25-6797)
It can help stabilize adjacent sliding framing.
We used it with our FTC Kiwi bot elevator this year.
You can see it sticking out of the right rear elevator column where two 6-32 screws hold it in place. With only two stages to elevate 27" we had to go with minimum overlap of stage columns (<3"), requiring slide plates be <2" engagement.
This gave too much wobble on full extension, but this little piece solved our problem so well that we even got gravity return to work reliably.
NOTE: PICs are from when we only elevated to 16" so side plates not fully spread.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
Unread 10-01-2013, 21:35
msheffels msheffels is offline
AKA: Mike
FRC #2498 (Bearbotics)
msheffels is an unknown quantity at this point
Re: 80/20 Channel
Perhaps two of these joined together, one for each piece of 80/20?
http://www.grainger.com/Grainger/802...CJ3?Pid=search
Unread 12-01-2013, 10:21
AKA: Dick Ledford
Re: 80/20 Channel
Yes, the C-shaped slider block is much stronger, but more appropriate for the heavier loads of FRC robots, and with three slide plates, also easier to be carrying the loads properly (unlike the bot in PICs above where shear is main loading on two slide plates).
-Dick Ledford
Unread 12-01-2013, 11:18
The Arizona Mentor
AKA: Andrew
Re: 80/20 Channel
-Dick Ledford
How much strength you need is certainly application dependent. If I'm building a basic elevator to lift 5 pounds 5 feet up I might not be too concerned about the shear loads on the plastic sliders (don't take that as an excuse not to check what the load ratings are on the sliders). If a robot plans on climbing using linear slides then proper sliding support and connections are a must for the mechanism to survive.
