Go to Post "Look, it's already weight optimized!" - Samk [more]
Unread 12-01-2013, 11:29
electricperson electricperson is offline
FRC #0240
electricperson is an unknown quantity at this point
VELOCITY
Anybody know how to come up with an equation or possibly the answer to the question that i need answered? I need to know the velocity of the discs when they are being launched across the field for my team.
Unread 12-01-2013, 11:47
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: VELOCITY
I'm going to assume you have a shooter. If you do, mount an encoder to the output shaft and measure the rotational velocity. The lowest speed recorded should be the muzzle velocity, if you keep the shooter at 100% power throughout the shot. If not, you can put a scale behind the shooter and videotape it, and measure the disc much the way Mythbusters measure velocity. (Scale has markings every couple inches, when you videotape it, you can move frame by frame to see the motion of the disc).
Someone has already posted some data on this; I am not going to spoon feed it to you. Use the search function to find it.
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 12-01-2013, 11:48
FRC #0240
Re: VELOCITY
alright. thank you.,
Unread 12-01-2013, 11:56
Re: VELOCITY
The frisbee velocity is half the tangential velocity of the spinning wheel (assuming no slipping).
Unread 12-01-2013, 13:54
AsianRookie AsianRookie is offline
AKA: Steven/Tim
FRC #0321 (Robolancers)
AsianRookie is an unknown quantity at this point
Re: VELOCITY
Well if you knew the rpm of your motor, then the velocity should be as followed.
RPM / 60 * PI * Diameter(probably in inches) / 39.3701(inches to meters) / 2(from the previous post above?) = velocity in meters/second
