Go to Post Beatings will continue until morale improves! - DampRobot [more]
Unread 06-01-2013, 20:13
Re: 2013 FRC Labview Registration issue
I apologize for the confusion. I'm personally not a big fan of SW licensing, and this is one of the reasons why. The standard process for manufacturing is to put a unique serial number on each package, but FRC is quite unique. By the time we received the folders, it was too late to do anything but roll with it. We are definitely redoing the packaging next year. We'll try to make the activation less confusing.
Greg McKaskle
Unread 07-01-2013, 21:06
tcjinaz tcjinaz is offline
Tim
FRC #3853
tcjinaz has a spectacular aura abouttcjinaz has a spectacular aura about
Actually, I think this was a good object lesson in RTFM. So much so I thought it was planned.
Software Mentor
3853 Pridetronics[
Unread 07-01-2013, 22:33
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Now how would that work out with NI knowing Greg sits on Delphi all night answering questions?
Unread 08-01-2013, 08:20
Not all night.
Greg McKaskle
Unread 08-01-2013, 16:43
Codec Codec is offline
Team 1418-Programming & Electronics
AKA: Shayne
FRC #1418 (FIRST Robotics Team 1418)
Codec is an unknown quantity at this point
We are still having an issue with registering using the actual serial number. The following message pops up:
Anyone have any ideas?
Unread 08-01-2013, 19:28
If you are still having licensing issues, please goto ni.com/frc and get help directly from the application engineers. The read these forums as well, but will likely be more effective there.
Greg McKaskle
Unread 09-01-2013, 20:16
AKA: Shayne
Thumbs up Re: 2013 FRC Labview Registration issue
Thanks for your help, turned out to be a bad install (insert sheepish smile here... o.O there are some dark smileys ) Anyways, a full un- and re-install worked and the new serial activated it!
Unread 12-01-2013, 11:02
nheft nheft is offline
FTC #0533 (Psichotics)
nheft is a jewel in the roughnheft is a jewel in the roughnheft is a jewel in the roughnheft is a jewel in the rough
I located the S14 S/N and it worked for all components EXCEPT the Application Builder. Has anyone else successfully activated the Application Builder with the S14 serial number?
Unread 12-01-2013, 12:26
Kevin Fort Kevin Fort is offline
no team (Team NI)
Kevin Fort is an unknown quantity at this point
LabVIEW shouldn't be activating as individual components but as one big bundle called FIRST Robotics Competition. The best way to see the status of your licenses and activate them is to open up the NI License Manager Program. If you open this do you see individual components listed under LabVIEW 2012 or one?
Unread 13-01-2013, 15:43
Squeaky4377 Squeaky4377 is offline
FRC #4377 (Boyne City Blaze)
Squeaky4377 is an unknown quantity at this point
Team 4377 is having some issues with our registration, as well. We've installed Labview, but when we tried to register the software, we were told that our serial number was invalid, even though it was fine when we installed Labview. Now when we open Labview, it says that it's in Evaluation Mode and that we cannot run programs this way. We're completely stuck on where to go from here.
Unread 13-01-2013, 18:28
If using the S14... serial number in the Activation screen doesn't fix it, you may need to contact NI technical support. See the Getting Started window, Support tab for the information.
Greg McKaskle
