Go to Post Everyone is reading way too much into this. The game piece is clearly a bunch of Opahs this year. Problem solved, case closed. Start designing your fish handling robots now. - Ryan Dognaux [more]
Unread 11-01-2013, 19:00
Nathan Powell's Avatar
Nathan Powell Nathan Powell is offline
The Prime Function
FRC #2582 (PantherBots)
Nathan Powell is an unknown quantity at this point
Driver Station Window Snap Error
I recently updated my team's driver station for this year's competition. However, when the program is opened, the upper and lower windows do not "snap" together, instead overlapping each other. Is this normal, or have other teams experienced this problem as well?
"What's this I keep hearing about always blame programming?"
Unread 11-01-2013, 19:02
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Driver Station Window Snap Error
I believe there is a button you can press to make this happen - I have not had much time to check out the new driver's station this year but I would expect it to be the same. They look like two buttons next to each other each with a box inside of it (at least on last year's DS).
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 11-01-2013, 19:16
The Prime Function
Would that button be on the driver station or the dashboard?
Unread 11-01-2013, 19:50
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Driver Station - Operation Tab - Windowed Mode
Above Team Station, below PC Battery.
Unread 11-01-2013, 20:11
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
On our classmate we've been having trouble getting them not to overlap even with it in the "snap" mode. It seems that if toggle the mode on and off several times, it will finally fit. It's a little disappointing that they've gone to the trouble to fix the imaging tool for the classmate, but they haven't gotten around to fixing the driver station CPU display or the snap mode issue.
Unread 11-01-2013, 21:35
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
The best advice I can give you to solve the Driver Station window overlapping is to create your own in labview. Create a new FRC Dashboard project and resize the components.
Unread 11-01-2013, 21:41
The Prime Function
All right, I'll give that a shot. It's not a vital function, but fixing it will help with viewing the driver station components. Thanks to everyone who offered their advice!
Unread 11-01-2013, 21:50
The plan is to correct the CPU usage in the same update as the new log file viewer. Since the cRIO CPU wasn't even available a few years ago, it wasn't deemed to be that critical of an issue.
I have never seen the snap or float fail to work. Do you have steps to reproduce the issue, or can you give a screenshot of it when it is not working?
Greg McKaskle
Unread 12-01-2013, 12:36
The Prime Function
Here are 2 screenshots: one with the driver station on top, and the other with the dashboard on top.
Name:	Driver Station snap error--Dashboard on top.png
ID:	13482  Click image for larger version
Name:	Driver Station snap error--DR on top.png
Unread 12-01-2013, 12:46
Hide your taskbar so that both windows will actually fit on screen and then re-dock the DS. Or boot into the "Driver" account where the DS is the shell.
Unread 12-01-2013, 13:23
The Prime Function
Those screenshots were taken from the "Driver" account. Here's what it looks like after hiding the taskbar. Also, the "window mode" button under the PC battery meter on the DS is unresponsive. Is that a glitch with the update, or just my driver station?
Name:	DS on top.png
ID:	13484  Click image for larger version
Name:	Dashboard on top.png
Unread 12-01-2013, 13:30
Interesting. In previous years the Driver account was set up to launch the DS as the shell so there shouldn't be a Task Bar. That must not be the case this year.
Unread 12-01-2013, 13:38
The Prime Function
Yeah, the DS worked fine last year. I'm not sure if other teams have this problem, or just mine.
Unread 12-01-2013, 14:26
It looks to me like the left button of Window Mode is pressed. Press the right one and the dashboard and DS will arrange themselves to the bottom left of the screen.
I can't really say how the Driver account is setup, but it looks to me like the Driver account should automatically set the window mode to be docked.
Greg McKaskle
Unread 12-01-2013, 15:26
The Prime Function
I noticed that too, but the button is unresponsive. If it is locked in the "non-snap" position then that would explain the issue. But nothing i've tried has fixed it--restarting the program and/or the computer, or reinstalling the update.
