Go to Post The only people who are dumb or ignorant in this world are the ones who don't stop and ask why. - T967 [more]
Unread 12-01-2013, 12:51
1757 1757 is offline
FRC #1757
1757 is an unknown quantity at this point
Roborealm cutoff on feed
Hey guys, when I do blob filtering, it usually will filter all blobs below a certain line on the feed. I don't have any idea why. An example is this brightness filter I have on my webcam feed, and as you can see, the bright blobs are filtered below the line where my face shows up.
If this could be fixed, thank you.
http://i.imgur.com/pY09H.png?1
Unread 12-01-2013, 13:31
FRC #1757
Re: Roborealm cutoff on feed
Unread 12-01-2013, 13:59
FRC #1757
notice how disgusting this cutoff is.
Unread 12-01-2013, 18:38
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
Can you post the .robo file?
Unread 13-01-2013, 00:46
RoboRealm RoboRealm is offline
FRC #0443
RoboRealm is a jewel in the roughRoboRealm is a jewel in the roughRoboRealm is a jewel in the roughRoboRealm is a jewel in the rough
The blob filter is meant to be used on a binary or very few colored image. Since you have not segmented the image in any way each pixel is seen as an object and the filter is running out of objects!
If you add in a Segment_Color, Reduce_Color, Color_depth, Flood_Fill, Auto_Threshold, etc. that will work better.
STeven.
Unread 16-01-2013, 15:17
FRC #1757
STeven.
