Go to Post We might not be as good as 217, or the other traditional "powerhouse" teams... but we are better because of them. Jason - dtengineering [more]
Unread 12-01-2013, 16:58
Derschatten Derschatten is offline
FRC #1203 (Pandemonium)
Derschatten is an unknown quantity at this point
Storage Question:
I already look at the manual and I can't find anything that would make this illegal. I was hoping someone from the community shed some light.
We have been kicking around an idea of making a left and a right storage tank. Then having a valve control which tank to fill to 125psi. Would that be legal?
Unread 12-01-2013, 17:03
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Storage Question:
I'm not sure if it would be legal or not but i assume they may have a problem with it if that valve is cutting off airflow to the vent and emergency relief valve.
What is the purpose of doing this?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 12-01-2013, 17:18
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
No, this setup would be illegal per R82:
R82
Only the compressor, relief valve (P/N: 16-004-011), pressure switch, pressure vent plug valve, pressure gauge, storage tanks, tubing, and connecting fittings may be in the high-pressure pneumatic circuit upstream from the regulator.
Also, just as note, per R81, your high pressure system is limited to 120 psi, not 125.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 12-01-2013, 17:36
slijin Thank You i must have miss that rule.
