Go to Post In my opinion, watching someone CAD is about as exciting as watching them sleep. - DampRobot [more]
Unread 12-01-2013, 18:03
ThePlagueDoctor's Avatar
ThePlagueDoctor ThePlagueDoctor is offline
ArduinoFTW
AKA: Anthony
FRC #0375 (The Robotic Plague)
ThePlagueDoctor is an unknown quantity at this point
Exclamation Shooter Problem
My team is doing the semi circle design for the shooter this year with one cim directly driven to a 8 inch high grip wheel. for the arc of the semi circle guard, we cut out a piece of plexiglass and positioned it at the perfect arc. It picks up the Frisbee fine, but it just doesn't fire it far at all. any ideas of what could be wrong?
Just remember, if a plague comes out of no where.... Well you know where it came from
<a href="http://www.thebluealliance.net/tbatv/team/375" style="border: 0"><img src="http://www.thebluealliance.net/tbatv/teambadge/gen/375/000000/FFCC00/teambadge.png" alt="Team 375" /></a>
Unread 12-01-2013, 18:07
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Shooter Problem
Move the wheel closer to the arc. aka more tension!
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Re: Shooter Problem
1) You may have too much or too little compression on the frisbee
2) You may be running the motor too slow or too fast
Unread 12-01-2013, 18:09
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Shooter Problem
A picture is worth a thousand words...can you post a picture of your setup? You may be doing something wrong that we can't tell from just your words.
Today we got about 35 feet travel from a single 8" kit wheel (from a few years ago) direct driven by a CIM, and less than 90 degrees of arc. We made the arc guide from a piece of 3/4" plywood, cut to the correct radius with a jig saw. We have about 1/8" compression on the frisbee as it travels thru the shooter. We also added a piece of wood on top to keep the frisbee from jumping up and losing grip.
One other problem we encountered is the wheel slipping on the motor shaft, we don't have the correct keyed hub yet.
Unread 12-01-2013, 18:35
ArduinoFTW
AKA: Anthony
Re: Shooter Problem
The wheel was slipping a little bit on the motor shaft, but we fixed that. we were using that exact same setup, except for the arc, we used a piece of plexiglass because the arc we cut out of half inch plywood was cut bad. i'll try the amount of compression tomorrow. Thanks
Unread 12-01-2013, 18:41
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Re: Shooter Problem
Try using a softer wheel like a AM pneumatic wheel. It allows more compression on the frisbee without the risk of deformation.
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 12-01-2013, 18:46
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Shooter Problem
The Plexiglas arc may be too slippery, and the frisbee is slipping instead of rolling along. You may want to add something soft and squishy there, like foam tape.
Unread 12-01-2013, 18:55
ArduinoFTW
AKA: Anthony
Re: Shooter Problem
The frisbee rolls and moves in the shooter just fine, its just that it doesn't launch that far, barely at all...
Unread 12-01-2013, 19:00
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: Shooter Problem
Our circular (90) degree shooter uses and AM pneumatic 7.5 inch wheel with a 32 tooth sprocket on it and a 25 tooth sprocket on the CIM. We have it set up so the wheel is hitting just above the widest diameter of the disk and just below the widest diameter of the tire with about 1/4 inch of compression and the tire at maybe 10psi. This ensures the disk does not ride up on the tire. This puppy will hit the top of a 10 foot door at 45 feet. up down variation is about 6 inches and side to side variation is almost nonexistent.
This is just with a plywood POC. You can read that as Proof of Concept or Piece of C&^%. Whatever. Still need to add a guide on the outer rail to keep the disk from riding up on that.
We have also tested a straight shooter bot so far it is not as consistent and much less powerful even with 2 wheel powered by separate CIMs.
Still plan on a little more testing here as I think it would be easier to incorporate to the robot.
Bruce
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 12-01-2013, 19:06
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
Re: Shooter Problem
One of the neat tricks we learned was to offset an 8" pneumatic wheel up slightly from the frisbee center. The wheels inherent compliance would push down slighlty on the frisbee. This downward force helped resist premature lift and kept the wheel in contact with its track. It adds to the overall friction of the system, but it helped on the Robot in three day build.
Can't be sure how effectively this would work on a stiff wheel.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 12-01-2013, 19:09
ArduinoFTW
AKA: Anthony
Re: Shooter Problem
Thanks. I have to try a lot of different things tomorrow.
Re: Shooter Problem
"Our circular (90) degree shooter uses and AM pneumatic 7.5 inch wheel with a 32 tooth sprocket on it and a 25 tooth sprocket on the CIM. This puppy will hit the top of a 10 foot door at 45 feet. up down variation is about 6 inches and side to side variation is almost nonexistent.
We have it set up so the wheel is hitting just above the widest diameter of the disk and just below the widest diameter of the tire with about 1/4 inch of compression and the tire at maybe 10psi. This ensures the disk does not ride up on the tire. Still need to add a guide on the outer rail to keep the disk from riding up on that."
Useful detail. Wish everyone would follow your example.
At your operating point, do you have any measurements of CIM voltage, current, and speed ?
Unread 12-01-2013, 20:47
hobbes20xxx hobbes20xxx is offline
AKA: Josh
FRC #2075 (Engima)
hobbes20xxx is an unknown quantity at this point
Re: Shooter Problem
Oddly, we found that running the CIM with a PWM input rate of ~50-60% worked the best.
Unread 12-01-2013, 20:50
Aroki's Avatar
Aroki Aroki is offline
FRC #1787 (Flying Circuits)
Team Role: CAD
Aroki will become famous soon enoughAroki will become famous soon enough
Re: Shooter Problem
What wheel were you guys using? Also did you use direct drive or have gearing (if so what ratio)?
Unread 12-01-2013, 21:00
Re: Shooter Problem
That gives you a lot of headroom to do closed-loop speed control. A bang-bang controller probably will work very well.
Also, interested in your answer to Aroki's questions about the gearing and the wheel.
