Go to Post ...many different kinds of students join our team. Some only have an interest in media, or others in cheering. What is important is that they are having fun while working in an engineering environment. - Bharat Nain [more]
Unread 10-01-2013, 15:43
anthonygraff24 anthonygraff24 is offline
FRC #2872 (CyberCats)
anthonygraff24 is an unknown quantity at this point
Gears for the CIM motor shaft not going on.
We were putting together the toughbox and when we had to put the 14 tooth key gear onto the CIM motor shaft, we couldn't get it on. It seems like the gear is too small to fit onto the shaft. Is anyone else having this problem, or is there any way how to fix it?
Unread 10-01-2013, 16:05
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Gears for the CIM motor shaft not going on.
Have you watched this video?
http://www.youtube.com/watch?v=uloJ0...ature=youtu.be
It's recommended that you put the pinion on with an arbor press or a rubber mallet.
If you're having trouble getting the pinion started on the shaft, make sure that there aren't any burrs or other surface defects on the shaft or pinion bore.
Unread 10-01-2013, 16:46
Some suggestions:
At 5:36 in the video, you might want to slip a properly-sized deep socket over the motor shaft and tap on the socket to drive the pinion on, instead of tapping on the edges of the pinion gear. Check frequently to make sure the key is aligned with the keyway in the pinion.
Also use a deep socket to tap on the gear at 2:36 in the video.
At 4:22 in the video, don't forget to grease the first-stage gear too.
Unread 10-01-2013, 20:37
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
We put our gears in the oven for a bit around 300 degrees and then use a drill press to push them on. We don't have an arbor press in our shop... Heat is wonderful thing when fitting close fitting parts, just remember not to touch them with bare hands for a while after doing this.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 12-01-2013, 19:24
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
SO.. In the past the gears have always just slipped on. Didn't see the vid before we assembled them so when they didnt just slip on I assumed it was just the plating gone bad causing the problem so we just ran an 8mm drill through them and on the went in the old way. Don't see why this would be a problem, the clip keeps them in place. Thoughts?
Bruce
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 12-01-2013, 20:13
We have pressed ours the last three years. Wouldn't mind if thy just slipped on as 8mm drill bits are rare in our school's shop...well, 8mm drill bits and everything else that even resembles a metric tool.
Andrew Basse
Unread 12-01-2013, 20:38
hobbes20xxx hobbes20xxx is offline
AKA: Josh
FRC #2075 (Engima)
hobbes20xxx is an unknown quantity at this point
truth!
Unread 12-01-2013, 23:11
DonRotolo's Avatar
Back to humble
FRC #0832
Huh. In our shop, it's both metric AND english tools. Come to think of it it's ALL our tools.
