Go to Post We don't use fancy tools like that, but we might need some wood glue or something :) - MrForbes [more]
  #31   Spotlight this post!
Unread 12-01-2013, 19:25
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: Best motor/gearing option to drive a shooter?
You posted this identical post in three different threads.
http://www.chiefdelphi.com/forums/sh...46#post1213846
http://www.chiefdelphi.com/forums/sh...56#post1213856
It might be better to post it once and provide a link.
Sorry didn't think about the link idea.
I'll do better next time.
Thanks
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
  #32   Spotlight this post!
Unread 12-01-2013, 19:26
Bruceb's Avatar
At full battery voltage and no speed control.
Ya, it's primitive but it works. We will be looking into PID or bang bang later.
  #33   Spotlight this post!
Unread 12-01-2013, 19:28
Originally Posted by DonRotolo View Post
Sounds like a direct drive to a 6" wheel would be the same.
The larger diameter provides a slightly longer contact path.
  #34   Spotlight this post!
Unread 12-01-2013, 19:30
Thanks
It's a great post though. The problem is, it's going to be difficult following the discussion. You've already got responses in two threads.
  #35   Spotlight this post!
Unread 12-01-2013, 19:32
Aroki's Avatar
Aroki Aroki is offline
FRC #1787 (Flying Circuits)
Team Role: CAD
Aroki will become famous soon enoughAroki will become famous soon enough
We were looking into gearing up our CIM motor to 6000-8000rpm and running an 8in pneumatic wheel. Originally we were looking to gear up a toughbox but after realizing that they only seel 12-14 teeth gears for CIM motors, we'll probably just use belts and sprockets
  #36   Spotlight this post!
Unread 12-01-2013, 19:34
FYI, Team 2073 found that above a certain wheel speed, the frisbee exit velocity actually decreased.
http://www.chiefdelphi.com/forums/sh...2&postcount=55
  #37   Spotlight this post!
Unread 12-01-2013, 19:37
smclean1969 smclean1969 is offline
FRC #3512
smclean1969 is an unknown quantity at this point
Something for the 8000 rpm, that's assuming free spin, which isn't accurate for a motor under load conditions. The CIM has to turn the wheel, so it's going to be something less than 8000. It won't be an amazing drop but 7000 - 7500 is probably more reasonable.
Scott McLean
FIRST Team 3512, the Spartatroniks
Team role: mentor
2011: Highest Rookie Seed and Rookie Inspiration Award Long Beach Competition
2012: Winner Los Angeles Regional -- w/ Team 987 and Team 1717
2013: Finalist Los Angeles Regional -- w/ Team 599 and Team 981; Engineering Excellence
2015: Entrepreneurship Award - Ventura Regional
  #38   Spotlight this post!
Unread 12-01-2013, 19:40
Could be a lot less than that if the wheel is generating vibration and windage.
Hint: measure the CIM current with a clamp-on ammeter. Then estimate the CIM speed from the voltage and current, as shown here.
  #39   Spotlight this post!
Unread 12-01-2013, 19:56
Aroki's Avatar
Team Role: CAD
This is definitely interesting, though they're using (from what I can tell)
8" Plaction Wheel from AndyMark while we're using a rubber wheel which may be turned to better fit the frisbee so I guess we'll have to build the belt/sprocket mockup before we can really test what the effective speed is.
  #40   Spotlight this post!
Unread 13-01-2013, 18:08
Who said they are running it at full voltage ?
http://www.chiefdelphi.com/forums/sh...40&postcount=7
  #41   Spotlight this post!
Unread 13-01-2013, 18:11
Anybody planning to buy 8" pneumatic and run it at 8000 rpm read this thread:
http://www.chiefdelphi.com/forums/sh...d.php?t=111118
  #42   Spotlight this post!
Unread 14-01-2013, 05:44
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
MrRiedemanJACC will become famous soon enough
Is there anyone considering using dual banebot 550's to drive their shooter?
  #43   Spotlight this post!
Unread 14-01-2013, 09:41
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Yes.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
