Go to Post Slight physical blocks will never stop a good programmer, we can just program around it. - AIBob [more]
Unread 12-01-2013, 20:18
java4first java4first is offline
(Java) Programming Mentor
AKA: Stu
FRC #0501 (Power Knights)
java4first is an unknown quantity at this point
Re: Video showing how to use Eclipse for FRC 2013 development without plugins
Hi -
Thanks for the video, we even managed to get this working for a couple of Macs that students are using for development. However, the problem is that it doesn't cover getting the "deploy" then "run" Ant targets working, only "build". Deploy seems to work - as it just builds the jars to deploy, but run fails because it is missing a setting for a property that has the IP address of the robot (and there may be other things once you get past this). I am guessing it's because we haven't 'configured' the plugin by adding the team number.
Has anyone figured out the last step in this process? Can you re-install last year's plug-in, and then just update to the new Java classes for this year? Or is there something simpler ...
Next year all us Eclipse users need to get together, and get at least one team on the Beta test - so that we can have an Eclipse plugin for doing development without having to resort to NetBeans. I don't care about all the new features of WPILib and any fancy wizards for coding ... I just want to be able to extend the SimpleRobot and deploy it via Eclipse.
Thanks in advance if you figured this out.
Unread 13-01-2013, 02:01
markmcgary's Avatar
markmcgary markmcgary is offline
Software Mentor
FRC #4322 (Clockwork Oranges)
markmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nice
Originally Posted by java4first View Post
Hi -
In my 'user' folder on my Mac is an 'invisible' file named ".sunspotfrc.properties". (Yes, it starts with a dot)
Inside this file are defined these properties:
sunspot.home=/Users/mark/sunspotfrcsdk
remoteaddress=10.43.22.2
wpilibj.home=/Users/mark/sunspotfrcsdk/lib/WPILibJ
The user folder name should be your user name. The 'remoteaddress' property will be your robot CRIO IP address, based on your team number.
I hope this helps.
Unread 01-02-2013, 13:30
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Hi -
So I am not sure why I didn't see any CD notifications for additional posts to this thread. I apologize for the delay in response, I believe you have overcome your problems, but I am going to answer your questions just in case anyone else stumbles upon this thread.
In the video around the 20:00 min mark, I show how to set up a deploy ant configuration to deploying code to the cRIO (not just building), and also show how to set up the debug configuration as well. The difference between these configurations and the build configuration is that you enter the IP address as an argument to the script -Dremoteaddress=10.xx.xx.xx (what ever IP your cRIO is).
Now this will work for you as long as you are updating a system that had previous FRC plugins (because you have a .sunspot.properties file in your home directory). One of the items I forgot to show in the video was updating the .sunspot.properties file.
This file lives in your home directory and was installed by the 2012 FRC Java plugins or the 2013 Netbeans plugins. So if you never installed the plugins (which you don't have too) you wont have this file, however this file tells the Build script where to find all the target files. So if you don't have a .sunspot.properties file in your home directory, create one. If you do, you can modify it. (note the period "." before the file name. ) You will need to show hidden files in order to see it. If you don't know what your home path is, type %HOMEPATH% in the run command on windows, or just open terminal on a mac. The properties file MUST BE saved in the home path or the build script in eclipse wont be able to find it, and then you won't have any ant target scripts.
The file defines the sunspot.home variable and the cRIO IP address. So it
should look something like this:
sunspot.home=C:/Documents and Settings/user/sunspotfrcsdk
remoteaddress=10.21.68.2
That's all the file needs to contain. So in this case, that path is the location of my 2013 sunspotfrcsdk folder and the remote address is the IP of my cRIO. If you have it set in the file, you do not need to set it in the arguments of the ant script like in the video. If you enter an IP address in the ant script argument, while having an IP in the properties file, the argument in the ant takes precedence over the text file.
I have been meaning to make this annotation in the video,
I just haven't had the time cause of the build season. :/
So sorry for any confusion,
Hope this helps,
-Kev
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
