| Thread Tools |
Rating:
Display Modes |
#211
Re: Climbing Mechanism Ideas
Well, I would say, "Hey, we have bumpers." And I can always install a parachute...
#212
re: "I simply use a spring loaded a "jumping" mechanism that would catapult my robot towards the top rung. While in mid flight, the robot reaches out and briefly touches level 1 and 2 in that order, then grasps on to the top rung."
There are some tough challenges here. The amount of power required to have a 120 lb (150 lb w/battery and bumpers) robot 'jump' ~9' is ridiculous and extremely dangerous. The skill level required to do this and touch the levels and then grasp the top row is outrageously difficult. You're much better off just grabbing the bottom row and picking up an easy 10 points. |
#214
Anyways... http://www.youtube.com/watch?v=6b4ZZQkcNEo Last edited by kevin.li.rit : 11-01-2013 at 23:05. |
#215
This year's rule limiting horizontal size AT ALL TIMES to staying within a 54" cylinder is very severe in light of the sloping nature of the climbing challenge.
How many people realize that if your robot is a cube of just over 31" on a side, then your diagonal is already at the 54" size limit. So suppose that during climbing your robot flips around or swings some as it transitioning levels, well you better not have a very tall or wide robot, or you are going to have one of your diagonal dimensions exceed the 54" diameter limit. We are thinking of having our robot lean over 30 degrees onto the pyramid corner, and establish a contact zone that bridges the dihedral angle, for extra stability as we transition the rungs, especially at the point where robot sits on only one rung while reaching for the next However, we then realized that this 30 degrees of lean over will SEVERELY limit what our initial footprint can be. Has your team taken this into consideration? What is the longest DIAGONAL dimension of your robot going to be, and how will robot movements during climbing cause this dimension to GROW in the horizontal projection of its length? There are going to be a lot of penalties for teams who overlook this. I see people talking about deploying gripper arms to swing themselves upward, but I suspect that unless they are very small, they will exceed the 54" horizontal diameter limit. Many other ideas being described are not taking this factor into consideration. My own opinion is that with this games design, there should have been some horizontal expansion allowance for robots in contact with the pyramid. -Dick Ledford |
#216
The 54" rule certainly makes the challenge harder but I think a lot of designs could still be done if the mounting location of the climber is changed on the robot frame. Remember that your initial frame doesn't have to stay parallel to the ground while climbing. |
#217
We had this amazing idea.. Then became stuck because of real estate
#218
Yes, if you can maintain proper orientation in the 54" cylinder, this can be handled, but robots tumbling out of controll are going to rack up plenty of technical fouls. -Dick Ledford |
#219
Robots tipping over are going to generate quite a few penalties this year. 30 point climbs will be huge match swings not only for the amount of points they score but for the penalty points they could cause if failed. |
#220
a lot of team doing like robot arm for climbing mechanism
#221
I don't think my team is capable of doing this, but one idea would be to "somersault" up the edge of the pyramid. I think this could be done pretty quickly and effectively, and I am even placing a bet that some of the top teams will do it. One example would be team 148's mechanism to grab onto the pole, lift itself up, then have a second arm on the other end of the robot grab on, the first arm would let go, the robot would flip using the second arm, and so on: http://www.youtube.com/watch?v=_hTyXQUgYLE
#223
Presumably, you'd just grab back on with the first arm again and repeat ( assuming arms with 180 degrees of rotation)
#225
We had more room than we thought, but less than we might want. |
