Go to Post Any metric you want to apply to Pink, they will pass with flying colors. Pun intended. - Lil' Lavery [more]
Unread 09-01-2013, 01:02
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
Re: January 8th Team Update
Originally Posted by dcarr View Post
But it is not contacting the pyramid in Zone 2.
I would deem this correct. It's all about contacting, not the airspace inbetween the levels, or as I have come to accept it as.
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Originally Posted by Christian2443 View Post
Are we allowed to hook on to horizontal bar 1 while still on level 0, and then pull themselves up. When I think about it, I think its not allowed because the robot is touching level 0, level 1, and inside the level 2 zone because we hooked onto horizontal bar 1.
http://www.youtube.com/watch?v=Bfyzb...SDSA& index=1
At 3:30, would this hanging method be legal?
If having robot components in level 2, but not touching any physical object that is part of level 2, would prevent a climb, then it would bar any robot over 30 inches tall from climbing. I think you're making this harder than it has to be.
The floor is level 0, the crossbar is level 1, nothing else gets touched, and the robot started on the floor. All is well.
Unread 09-01-2013, 01:07
TheMadCADer TheMadCADer is offline
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
Don't worry about which zones the robot is in, just the zones it is contacting. The location of the robot doesn't matter at all until the match ends and they check your height.
In your "hook bar 1 and pull up" scenario, the robot touches zone 0, then zone 0 and a bar in zone 1, then only a bar in zone 1, coming to rest with the lowest point of the robot being contained in zone 1. Scenario-bot scores 10 points for its alliance.
Unread 09-01-2013, 01:10
Christian2443's Avatar
Christian2443 Christian2443 is offline
FRC #2443
Christian2443 is an unknown quantity at this point
Thank you everyone for there help! My team has been trying to build a robot to get around our current understanding. Some of us are thinking of pneumatic jumping, or using the slanted bar to climb instead.
Unread 09-01-2013, 05:53
galewind's Avatar
galewind galewind is offline
... more like a temperate breeze
AKA: Chris Gregory
FRC #1089 (Team Mercury)
galewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond repute
Send a message via AIM to galewind
Does this now clarify the notion that robots need to be "hanging out" in zone 3 at the end of the match to receive the 30 point bonus? Or does it basically say "you'll get the points when the match is over". Before it used to say "by" the end of the match, and now I think it's saying "after 5s after the match is over".
Chris G
Advisor, Team Mercury (1089), Hightstown High School
Unread 09-01-2013, 06:17
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Yes, the update states that points are assessed based off the lowest point of the robot "at the point in which final scores are assessed per Section 3.2.4", which would be the five seconds after the match.
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
The known issues link is a great step forward. Thanks FIRST
Unread 09-01-2013, 11:18
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is online now
FRC #2363
I'm bothered by the new language of 3.1.5.2, which now uses the word "point" to mean three different things in the same paragraph:
The Level to which a ROBOT has CLIMBED is determined by the lowest [physical location] of the ROBOT (in relation to the FIELD) at the [moment in time] in which final scores are assessed per Section 3.2.4. CLIMB [game score] values and Levels are defined in Figure 3-4.
Unread 09-01-2013, 11:51
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
I would say that is a legal climb to level 1 for a 10 point bonus as per the climb rules.
One I did notice was the team would have been given a foul when the person that was feeding frisbees to the bot passed his hand into the game area. Opps, big safety issue.
Unread 12-01-2013, 12:29
CLandrum3081's Avatar
CLandrum3081 CLandrum3081 is offline
Alumni? Wait, what?!
AKA: Catherine Landrum
FRC #3081 (RoboEagles)
CLandrum3081 has a reputation beyond reputeCLandrum3081 has a reputation beyond reputeCLandrum3081 has a reputation beyond reputeCLandrum3081 has a reputation beyond reputeCLandrum3081 has a reputation beyond reputeCLandrum3081 has a reputation beyond reputeCLandrum3081 has a reputation beyond reputeCLandrum3081 has a reputation beyond reputeCLandrum3081 has a reputation beyond reputeCLandrum3081 has a reputation beyond reputeCLandrum3081 has a reputation beyond repute
This may be my sleep deprivation-induced stupidity, but I'm a little unclear on something. Does an alliance receive points for EACH robot on the pyramid, or just the highest robot on the pyramid?
FRC Team 3081 John F. Kennedy HS RoboEagles
2012: Rookie, person who does anything everyone else is too lazy to do, de facto scouting lead
2013: Co-Captain and Build Lead who still does anything everyone else is too lazy to do
2014: Co-Captain (AGAIN?!) and Scouting/Strategy/CAD/Pit Representative who has finally learned how to delegate tasks to others responsibly
2012 MN Land of 10,000 Lakes Regional Champions (with 3747 ChaoTech and 525 Swartdogs)
2012 Inaugural MN State High School League 2nd Seed Alliance Captain and Runner-Up (with 3747 ChaoTech and 2232 Deus Ex Machina)
2013 Ehm.... not much! Attended Northern Lights and 10K
2014 Attended Wisconsin and MN Land of 10K Lakes Regionals
Unread 12-01-2013, 22:11
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Each.
Unread 13-01-2013, 12:51
Thanks! My team was under the impression it was only the highest robot. We were still unclear after several reads through the manual.
Unread 13-01-2013, 13:16
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
While Max is correct, don't just take the word of someone on CD. Especially don't base your strategy around one post. Read the manual to find the answer, it isn't that hard. If you still can't find the answer, ask someone to quote the rule for you.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 13-01-2013, 16:19
Thanks, I'll keep that in mind in the future. I've read through the manual (especially that particular section) several times and it just wasn't clicking. I also find it interesting that it hasn't come up in Q&A yet, and it won't let me submit a question because I'm a new user. I just hoped different perspective on the rule would help it make more sense - even other team members were confused, especially after this update.
