Go to Post There are always going to be tough calls, and you just have to trust in your officials to do the right thing. - Jeff Waegelin [more]
Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
  #211   Spotlight this post!
Unread 11-01-2013, 22:53
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Climbing Mechanism Ideas
Originally Posted by Kevin Sevcik View Post
I'm enjoying imagining the look on your Lead Robot Inspector's face when you tell him that.
Well, I would say, "Hey, we have bumpers." And I can always install a parachute...
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
  #212   Spotlight this post!
Unread 11-01-2013, 22:57
pfreivald's Avatar
AKA: Patrick Freivald
...at which point Ether would post a pithy comment about the math underlying the parachute and why this is unwise.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #213   Spotlight this post!
smclean1969 smclean1969 is offline
FRC #3512
smclean1969 is an unknown quantity at this point
re: "I simply use a spring loaded a "jumping" mechanism that would catapult my robot towards the top rung. While in mid flight, the robot reaches out and briefly touches level 1 and 2 in that order, then grasps on to the top rung."
There are some tough challenges here. The amount of power required to have a 120 lb (150 lb w/battery and bumpers) robot 'jump' ~9' is ridiculous and extremely dangerous. The skill level required to do this and touch the levels and then grasp the top row is outrageously difficult. You're much better off just grabbing the bottom row and picking up an easy 10 points.
Scott McLean
FIRST Team 3512, the Spartatroniks
Team role: mentor
2011: Highest Rookie Seed and Rookie Inspiration Award Long Beach Competition
2012: Winner Los Angeles Regional -- w/ Team 987 and Team 1717
2013: Finalist Los Angeles Regional -- w/ Team 599 and Team 981; Engineering Excellence
2015: Entrepreneurship Award - Ventura Regional
  #214   Spotlight this post!
Unread 11-01-2013, 23:03
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Is it more realistic and safer if my robot is 60 lbs including battery and bumper?
Anyways... http://www.youtube.com/watch?v=6b4ZZQkcNEo
Kevin Li
596 - Sciclones
  #215   Spotlight this post!
Unread 11-01-2013, 23:26
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
This year's rule limiting horizontal size AT ALL TIMES to staying within a 54" cylinder is very severe in light of the sloping nature of the climbing challenge.
How many people realize that if your robot is a cube of just over 31" on a side, then your diagonal is already at the 54" size limit.
So suppose that during climbing your robot flips around or swings some as it transitioning levels, well you better not have a very tall or wide robot, or you are going to have one of your diagonal dimensions exceed the 54" diameter limit.
We are thinking of having our robot lean over 30 degrees onto the pyramid corner, and establish a contact zone that bridges the dihedral angle, for extra stability as we transition the rungs, especially at the point where robot sits on only one rung while reaching for the next
However, we then realized that this 30 degrees of lean over will SEVERELY limit what our initial footprint can be.
Has your team taken this into consideration?
What is the longest DIAGONAL dimension of your robot going to be, and how will robot movements during climbing cause this dimension to GROW in the horizontal projection of its length?
There are going to be a lot of penalties for teams who overlook this.
I see people talking about deploying gripper arms to swing themselves upward, but I suspect that unless they are very small, they will exceed the 54" horizontal diameter limit.
Many other ideas being described are not taking this factor into consideration.
My own opinion is that with this games design, there should have been some horizontal expansion allowance for robots in contact with the pyramid.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
  #216   Spotlight this post!
Unread 12-01-2013, 11:35
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Maybe I'm missing something here... when a 31" cube sits flat on the ground its diagonal dimension in the horizontal plane is ~44". Or are you referring to the fact that when this cube is rotated 45 degrees from the horizontal plane then its diagonal dimension is ~54" horizontally? Depending on your climbing method your robot may not ever rotate to 45 degrees, given that the pyramid is 60/68 degrees based on your approach.
The 54" rule certainly makes the challenge harder but I think a lot of designs could still be done if the mounting location of the climber is changed on the robot frame. Remember that your initial frame doesn't have to stay parallel to the ground while climbing.
  #217   Spotlight this post!
Unread 12-01-2013, 12:01
April McShorty April McShorty is offline
Most Senior Member (Grandmama)
AKA: April Tobergte
FRC #0240 (Tempest)
April McShorty is an unknown quantity at this point
We had this amazing idea.. Then became stuck because of real estate
  #218   Spotlight this post!
Unread 12-01-2013, 18:34
AKA: Dick Ledford
I am referring to the cube's diagonal as being the segment going through 2 corners AND the CENTER of the cube, not the FACE diagonal going thru the center of any face.
Yes, if you can maintain proper orientation in the 54" cylinder, this can be handled, but robots tumbling out of controll are going to rack up plenty of technical fouls.
-Dick Ledford
  #219   Spotlight this post!
Unread 12-01-2013, 20:26
The Arizona Mentor
AKA: Andrew
That makes more sense, I was looking too literally at how a robot might lean to get on the pyramid.
Robots tipping over are going to generate quite a few penalties this year. 30 point climbs will be huge match swings not only for the amount of points they score but for the penalty points they could cause if failed.
  #220   Spotlight this post!
Unread 12-01-2013, 20:55
Dinoyan Dinoyan is offline
Team Role: Electrical
Dinoyan is an unknown quantity at this point
a lot of team doing like robot arm for climbing mechanism
  #221   Spotlight this post!
Unread 12-01-2013, 21:02
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
GDC has a fun definition of "continuously".
Originally Posted by Q89
Q. How long does a tipped robot have to right itself before it is assessed a TECHNICAL FOUL under G23? Is there anything a tipped robot can do to avoid a TECHNICAL FOUL? Is the TECHNICAL FOUL still assessed if a robot is tipped by the actions of an opposing team?
A. A tipped ROBOT will not be considered "continuously" breaking [G23]. Please see Team UPDATE 2013-01-11 in reference to your final question.
  #222   Spotlight this post!
Unread 12-01-2013, 21:21
swwrobotics's Avatar
swwrobotics swwrobotics is offline
FRC #2900 (The Mighty Penguins)
swwrobotics is an unknown quantity at this point
I don't think my team is capable of doing this, but one idea would be to "somersault" up the edge of the pyramid. I think this could be done pretty quickly and effectively, and I am even placing a bet that some of the top teams will do it. One example would be team 148's mechanism to grab onto the pole, lift itself up, then have a second arm on the other end of the robot grab on, the first arm would let go, the robot would flip using the second arm, and so on: http://www.youtube.com/watch?v=_hTyXQUgYLE
  #223   Spotlight this post!
Unread 12-01-2013, 21:41
I keep seeing this suggestion, and I keep wondering what exactly the plan is after the second bicep curl leaves the robot 4 feet in the air with its wheels facing the pole.
  #224   Spotlight this post!
Unread 12-01-2013, 22:04
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Presumably, you'd just grab back on with the first arm again and repeat ( assuming arms with 180 degrees of rotation)
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
  #225   Spotlight this post!
Unread 12-01-2013, 22:22
pfreivald's Avatar
-Dick Ledford
To get a proper handle on what we were dealing with, we drew out on large, taped-together pieces of paper a 54" circle, a template of our robot frame plus bumpers, and a top-down view of one "zone" of the pyramid corner (post-bottom to knuckle-top).
We had more room than we thought, but less than we might want.
Team 1551
I write books, too!
