Go to Post Go get Al, he probably isn't busy! - Jimmy Nichols [more]
Unread 12-01-2013, 22:43
bulky234 bulky234 is offline
Darius DeSpain
FRC #3008 (Falcons)
bulky234 is an unknown quantity at this point
cRIO imaging issue
For the past 2 or 3 days i've been trying to get my cRIO to image properly, but it keeps either getting stuck on rebooting compactRIO or it fails saying to check the IP reset switch on the cRIO. I've tested it both on the 4 and 8 slot cRIOs and two different computers and i've had one of my very experienced mentors go over the wiring and manuals with me and we can't seem to get it to work. NEED HELP!
Unread 12-01-2013, 22:50
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: cRIO imaging issue
Are you imaging over wifi or ethernet? Be sure to use a wired connection because wireless can be disconnected and cause some of the problems you are encountering.
All opinions are my own.
Unread 13-01-2013, 01:22
William Kunkel William Kunkel is offline
Programming Lead
AKA: Kunkel
FRC #0422 (Mech Tech Dragons)
William Kunkel is an unknown quantity at this point
What have you tried? Have you reset the cRIO to factory defaults, i.e. hold the reset switch? Are your DIP switches all turned off? Is your computer using a static IP? It should be set 10.(first 2 digits of team #).(second 2 digits of team #).6 . Are you using the right subnet mask (255.0.0.0)? Have you installed the update to the imaging tool?
Unread 13-01-2013, 02:16
Darius DeSpain
FRC #3008 (Falcons)
I have been using a wired connection to the cRIO and i might have to play around with the IPs more from the looks of it. I've tried reseting it and all of the DIP switches are off. I've updated my imaging tool many times and reinstalled it a few times. It may be the IPs that have been messing me up though. Have to double check on monday
Unread 13-01-2013, 02:36
ElJeffe3255's Avatar
ElJeffe3255 ElJeffe3255 is offline
AKA: El Jeffe
FRC #3255 (SuperNURDS)
ElJeffe3255 is an unknown quantity at this point
We had this problem earlier this year and found some threads that led to causes. Can't recall which one clinched it, but here are some keys.
1. You must be wired.
2. You must have your wireless adapter disabled.
3. Use a hub/switch (like the d-link) between the imaging computer and the cRIO. The reasoning is that it keeps the port open on the imaging side while the cRIO boots. Otherwise they can lose comms across the reboot.
4. Follow the IP address and net ask instructions closely.
5. Make sure your Ethernet adapter doesn't have multiple IP addresses configured. Click on the advanced button on the TCP/IP properties dialog to see if this is the case.
Unread 13-01-2013, 10:24
jcbc's Avatar
jcbc jcbc is offline
AKA: Julie
jcbc is a jewel in the roughjcbc is a jewel in the roughjcbc is a jewel in the roughjcbc is a jewel in the rough
We always use a crossover Ethernet cable when imaging. I don't see it in this year's documentation, but last year's documentation (Getting Started with the 2012 FRC Control System) said to use a crossover cable on page 17, step #1 under "Running the cRIO Imaging Tool".
Unread 13-01-2013, 10:30
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Generally speaking, any newer computer knows when to crossover and when not to, so that shouldn't be the problem (but it might!).
We actually got stuck at the rebooting point, and I'd never seen it before. We found a couple things. First, the battery was nearly dead. Next, the cRio wasn't being powered from the 24V on the power distribution board. Fixing those allowed a reimage (wierd huh?).
Unread 13-01-2013, 10:52
Jay1986's Avatar
Jay1986 Jay1986 is offline
Programmer and Driver
AKA: Jay Urban
FRC #1986 (Team Titanium)
Jay1986 is a jewel in the roughJay1986 is a jewel in the roughJay1986 is a jewel in the roughJay1986 is a jewel in the rough
Did you update the software that was released 01/11/13? This happened to me and later realized there was an update.
2013 Oklahoma Regional (Regional Winner, Gracious Professionalism, [and judges voted me star of the day])
2013 KC Regional (Regional Winner, Woodie Flowers, Industrial Design)
2013 Hub City Regional (Regional Winner, Entrepreneurship, Quality, Dean's List)
Unread 13-01-2013, 11:41
ctccromer's Avatar
ctccromer ctccromer is offline
Animus
AKA: Tucker Campbell
FRC #3753 (Bulah Bots)
ctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to all
I had issues with it too. For whatever reason, when I tried to image it on my laptop, it wouldn't find the cRIO. I could ping it and everything but the imaging program wouldn't find it.
The program worked fine on the white clamshell laptop, so we just imaged it on that one, then did everything else on mine. So i guess just try another laptop
Team 3753 BulahBots
Unread 13-01-2013, 19:56
jcbc's Avatar
AKA: Julie
Looking at NI's documentation for the regular non-FRC version of the cRIO II (cRIO-9075/9076, page 12), it says: "use an Ethernet crossover cable to connect the chassis directly to a computer". I don't know if it is the issue that some teams are having, but I thought I would mention it since it was in last year's documentation.
We were trying something out today and discovered that all of the indicator lights on the cRIO can be on but if the battery doesn't have enough power, LabVIEW won't be able to connect to the cRIO to deploy code to it. The cRIO is picky about having enough power.
Unread 14-01-2013, 14:13
itsjustmrb itsjustmrb is offline
FRC #4063 (TRikzR4kiDz)
itsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to behold
Darius,
I sent you a pm as to what worked for us when we were having the issues you are having. If you haven't fixed it yet, please reply and I will walk you through the process.
Mr. B.
2016 Hub City Regional Winner #3 Seed (3310 & 4301)
2016 Bayou Regional Winner #1 Seed (233 & 4087)
2015 Dallas & Alamo Creativity Award
2015-2016 Hub City Regional Gracious Professionalism
2014 Hub City Regional Engineering Inspiration
2012-2016 Alamo Regional Gracious Professionalism
2016 Bayou Regional Gracious Professionalism
2014 Dallas Regional Gracious Professionalism
2013 Alamo Regional Winners (2468 & 2789)
Unread 14-01-2013, 16:02
Falcon Falcon is offline
Ron Faulkner
AKA: Ron Faulkner
FRC #2451 (PWNAGE)
Falcon is an unknown quantity at this point
1. Turn on DHCP in your D-Link.
2. Set your computers Ethernet to Auto.
3. Unplug PC from D-Link.
4. Power cycle D-Link/cRio
5. Plug computer back into D-Link.
6. Run the Imaging tool.
You lose contact with the cRio as it changes IP addresses. But it will request DHCP service which will allow you to keep in contact with it throughout the imaging process. Don't forget to turn DHCP back off in the D-Link or run the bridge configurater again.
Unread 15-01-2013, 17:58
Hebrew Hebrew is offline
FRC #4228 (iRobotics)
Hebrew is an unknown quantity at this point
I am haing the same issue, I tried the DHCP with the dLink but it still will not reboot. Any other method that might work?
Unread 15-01-2013, 18:00
Darius DeSpain
FRC #3008 (Falcons)
I just fixed the problem. Try check your computer and ethernet cable. That seemed to be the problem for me. Once i switched cables it worked fine
Unread 15-01-2013, 19:29
The weird thing with mine is it is not showing the modules on the crio on the imaging tool either...
I tried the router and three different ethernets
