Go to Post Sir, you vastly underestimate the destructive power of a teenager. - DonRotolo [more]
Unread 12-01-2013, 20:09
Bearingman Bearingman is offline
FRC #3473
Bearingman is an unknown quantity at this point
Is anyone having trouble with the gearbox?
The gearbox that we got from the kitbot has been having problems. When we tighten the gearbo completely, the shaft locks and becomes EXTREMELY diffucult to rotate. We talked to our mentors about loosening the gear box, because it let the shaft rotate more freely on its axis but he also said it had a preset torque setting that we should try to match. Does anyone have any ideas that we can use to solve this problem.. Is anyone else having a similar problem? The collars of the bearings are on the wroong side.. or at least thats whay my teamates tell me but some say it doesn't matter
Unread 12-01-2013, 20:25
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Is anyone having trouble with the gearbox?
Did you grease the gears and follow the instructions?
Lack of grease magnifies the effects of friction on the system, which reduces efficiency and accelerates wear, as well as cause the symptoms you describe.
When you say "the collars of the bearings are on the wrong side," do you mean that the flanges are on the wrong side? If that is the case, then you will indeed run into issues because 1) the bearing's effective depth inside the gearbox will be different and 2) the bearing will eventually slide off the shaft because the flange is not retaining it.
What did your mentor mean by a "preset torque setting"?
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 12-01-2013, 20:31
Take it apart and assembly it properly. Nothing less will do.
http://www.youtube.com/watch?v=uloJ0...ature=youtu.be
Unread 12-01-2013, 21:14
FRC #3473
Thanks everybody We tried taking it apart and this is my first time working with gearboxes so its a great help to have people here to help us with it.
Unread 12-01-2013, 22:54
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Does this mean it works now or that you reassembled it and it still doesn't work?
