Go to Post Don't just assume that because you can modify an existing design that you are an engineer. - Daniel_LaFleur [more]
Unread 19-01-2003, 16:17
Simon G Simon G is offline
no team (Cheshire Choppers)
Simon G is an unknown quantity at this point
Angry Specs full of errors???
Ok, I was looking at the spec pages for the FP and globe motors. I recall from past years, that these spec sheets have errors (it looks like they used the same file, and never fixed the errors)
First:
Stall torque for the FP motor is listed as:
0.380 N-m (mili-NEWTON meters)
What are they talking about? It must be N-m, not mN-m, because there would be no way you'd get 34.7 N-m with a 124:1 gearbox.
Second:
RPM for globe motor only: 97 RPM. Globe motor & gearbox, 87 RPM. Yet the torque goes from 30 oz-in to 150 in-lbs... something doesn't compute... I'll believe the other data that says that the motor-only gives around 11500 rpm.
Obviously, most people on this board already realize these errors, because a lot of this data is in the white papers (from other sources, not FIRST)
I guess I wanted to gripe, because not only do we get specs (finally) 2 WEEKS into the competition, but they're also so obviously wrong.
Lesson to learn: always apply a "garbage" filter to any data you use, and ask the question "does this number make sense?"
my $0.02
Simon
Unread 20-01-2003, 12:53
gc02 gc02 is offline
gc02 is on a distinguished road
I feel your pain. I'm always looking for new motors to add to our simulator, EDTSim, and am constantly coming across similar inconsistencies and omissions of key information.
I don't know if that's part of what FIRST intends to teach, but that is an excellent lesson to learn.
Greg
Enigma Industries
Signal specs for FIRST contorllers Tim Skloss Technical Discussion 6 31-08-2003 18:30
Digital inputs, bandwith, errors? Micah Brodsky Programming 7 20-01-2003 16:08
Q&A Discuss: Are specs available on the new motors/mounts? CD47-Bot Extra Discussion 3 15-01-2003 19:39
Looking for full playing field archiver 2001 1 24-06-2002 00:13
Motor specs kmcclary Off-Season Events 4 26-10-2001 22:41
