Go to Post Don't worry so much about the wording of the rules but the intent of the rules. - Greg Needel [more]
Unread 13-01-2013, 01:13
Kusha's Avatar
Kusha Kusha is offline
Crimpin' ain't easy
AKA: Kusha Gharahi
no team (Looking for a team)
Kusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the rough
2 wheels vs 1 wheel in a linear shooter
What are the advantages to having two wheels in a linear shooter? Disadvantages?
https://kusha.me
Unread 13-01-2013, 01:16
hugo3337's Avatar
hugo3337 hugo3337 is offline
FRC #3753 (BulahBots!)
hugo3337 is on a distinguished road
Re: 2 wheels vs 1 wheel in a linear shooter
your frisbee has better momentum with two wheels. Unless your motor is good enough that it can take care of that. Also to make sure that after you shoot it reaches top speed faster with two since when using only one youre asking your motor to do more work. Hope this helps!
the down side is that youre using an extra motor and adding some more weight.
Unread 13-01-2013, 01:20
Kusha's Avatar
Crimpin' ain't easy
AKA: Kusha Gharahi
Does it have better momentum because of the increased contact? And wouldn't the frisbee have the same speed of the last motor?
https://kusha.me
Unread 13-01-2013, 01:26
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Our understanding is the additional contact time results in higher speed.
With one wheel, the frisbee just touches the wheel for a fraction of a second. Two wheels allow for a preliminary speed-up followed by a final acceleration and fly-out of the shooter.
A circular pathway shooter allows vast amounts of contact but has its own flaws. It seems like the linear shooter compensates for this lack of contact by having two wheels.
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 13-01-2013, 01:33
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Additional contact helps as does avoiding slippage but I think it is more about the relative rotation. The max velocity you can impart with one wheel is half the tangential velocity (because the frisbee is also rotating in proportion to the wheel's rotation and in the opposite direction). With two wheels you can approach the tangential velocity.
You want the firsbee to spin for stability so if using 2 wheels I think one might try running the two wheels at slightly different speeds.
HTH
Unread 13-01-2013, 09:29
I believe the 2 wheels we are talking about here are on the same side of the frisbee (i.e. both wheels are opposite the guide rail).
With 2 wheels, the maximum frisbee speed is still half the wheel tangential velocity.
Name:	2 wheel linear.jpg
Unread 13-01-2013, 11:46
ctccromer's Avatar
ctccromer ctccromer is offline
Animus
AKA: Tucker Campbell
FRC #3753 (Bulah Bots)
ctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to all
Just out of curiosity, has anyone tried using two wheels with one on each side of the shooter? My team prototyped the common build with 2 wheels on the same side, but I'm curious how the other 2 wheel build would work
Team 3753 BulahBots
Unread 13-01-2013, 13:34
pleaseignore's Avatar
pleaseignore pleaseignore is offline
Former Member
AKA: Andrew Hagen
FRC #2883 (Fighting Rednecks Engineering and Design)
pleaseignore is an unknown quantity at this point
What's wrong with a circular path?
Unread 13-01-2013, 13:39
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Search is your friend. Discussed at length in that thread.
Academic Student (Forever)
Unread 13-01-2013, 13:48
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Frisbees, in general, work by spinning, so having wheels on only one side is just a more elegant and efficient way of imparting spin.
Here's another reason why two wheels is theoretically better than one: Let's say you spin your one wheeled shooter up to a set speed. When the Frisbee contacts it, momentum will be lost, so the Frisbee will leave at less than half the original set speed. The motor can compensate by accelerating the wheel back to its original speed, but more likely than not, the Frisbee will already be gone by then. Two wheels allows you to "sacrifice" the first wheel's momentum so that you don't have as much of a momentum loss at the final wheel.
This is also why a curved track or a belt on a linear track is nice for hurling discs because there is a long period of contact during which the flywheel/Frisbee system recovers any lost momentum.
Of course, I may be unintentionally exaggerating - I have no idea whether the loss of momentum is actually consequential, since I haven't done any of the math.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 13-01-2013, 18:07
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
Others answered, but here is the physics 1 equation:
The impulse momentum theorem
F Δt = m Δv
How much force AND how long you apply it determine your change in momentum. More contact = more time
Unread 13-01-2013, 18:52
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Has anyone out there tried three wheels in a linear shooter?
Faridodin "Fredi" Lajvardi KD7WKD
Unread 13-01-2013, 19:13
Oldbikerider's Avatar
Oldbikerider Oldbikerider is offline
AKA: Graham
FRC #3132 (Thunder Down Under)
Oldbikerider will become famous soon enough
Our team is also interested in people's thoughts and/or experiences with a 3 wheel linear shooter. If we go with a linear shooter we're thinking of allowing to add a third wheel if it should be necessary.
There are other ways of adding speed to a two wheel shooter, such as a pneumatic or spring trigger mechanism. Until we finish testing, we're keeping all options open for now.
Graham.
Unread 13-01-2013, 19:26
I'm skeptical that a third wheel is necessary.
My engineering intuition tells me that the first wheel should be governed at a speed approx 75% of the second wheel. You should then be able to get plenty of exit velocity without slipping.
Has anyone out there tried a speed difference of this magnitude?
Unread 13-01-2013, 19:34
AKA: Graham
We're hoping two are sufficient. Our tests indicate that it can probably be done with two.
I also question why a speed differential is needed. Why not just impart as much energy as you can with each wheel? We're not looking to maximize efficiency here, just fire discs as fast as possible. What is wrong if the first wheel got the disc to near full speed, then the second wheel doesn't have to do much more.
Graham.
