Go to Post Honestly, I always thought that the true meaning for nerd was an intellectual badass. - rcmolloy [more]
Unread 13-01-2013, 01:16
Trish Fisher Trish Fisher is offline
FRC #2240 (Brute Force)
Trish Fisher is an unknown quantity at this point
ideas for a strong hook
Our team spent a lot of time searching the internet to find a hook to hook onto the horizontal bar that could hold over 100 lbs. We didn't have much success.
Can anyone give ideas where to buy one or how to make one? We are a young team, so we don't have much fabrication experience. It would be better if we could buy one then figure out how to attach it to our ascension mechanism (which we are still working on too). Right now the hooking spot is a horizontal piece of steal, so if the hook was connected to a flat piece where we could just screw it onto our steal plate, that would be perfect!
Thanks!
Last edited by Trish Fisher : 13-01-2013 at 01:20. Reason: Added information for attaching hook to mechanism.
Unread 13-01-2013, 01:25
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #0020 (The Rocketeers)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Re: ideas for a strong hook
http://www.mcmaster.com/#rigging-rope-hooks/=l0gzlo
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Bent aluminum rod worked for us in '10. We fell once but it was because of a bent eye hook, never had a problem with the actual hook.
Unread 13-01-2013, 03:17
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
We went with a modified shark hook in 2010; it was fashioned from some black steel IIRC. Worked like a beaut.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 13-01-2013, 09:46
dipmeinaluminum's Avatar
dipmeinaluminum dipmeinaluminum is offline
Michael Vilarelle Mentor
AKA: (Former Mentor 354 Westinghouse Pirates)
FRC #0333 (The Megalodons)
dipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to behold
If you make something from scratch, use extremely few parts, let's chances for failure.
May I suggest Lexan, or square tubing.
Team#333 (2013-Present)
Team#354 (2000-2013)
https://www.youtube.com/watch?v=Bu5-NvMUQ-Y
Unread 13-01-2013, 10:13
Thank you for these ideas, keep them coming if you can
Unread 13-01-2013, 10:34
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I have a vise, torch, and big hammer in my shop, so I could probably make a hook from steel that would work. But I don't know what you have available.
If you have a jig saw or band saw, you could cut a hook from sheet aluminum rather easily. You might need to order the aluminum though, if you live in a small town. 1/8" aluminum will probably work, if you design the hook so it has sufficient width.
Also, not having any idea what you are going to attach the hook to, it's hard to be more specific about how you could make the hook.
and plywood works too! http://www.chiefdelphi.com/forums/sh...d.php?t=111128
Unread 13-01-2013, 10:52
Chris is me's Avatar
AKA: Pinecone
It's not too hard. Bend some aluminium rod in a pipe bender, mill a hook out of some 1/4" plate, make some out of thinner plate and standoffs... whatever works for you. I bet you could do it with Kitbot frame material.
Unread 13-01-2013, 11:24
Repurposing some C-clamps might be a reasonable approach. Particularly ones similar to this http://www.sweetwater.com/store/detail/CClamp
Or use them as inspiration for building your own.
Greg McKaskle
Unread 13-01-2013, 11:28
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Here's a fairly simple one to make.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 13-01-2013, 13:55
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
If you decide to make your own (I personally wouldn't because I was also an eyewitness to the incredible badassery of a shark hook - it's very light and it's just about the right size for the pipes once you grind the barb off), you can easily model a hook in any material in either Solidworks or Inventor and then run a simulation to see if it would yield under the 100+ pounds of force. I'd be happy to explain the process if you're curious.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 13-01-2013, 17:14
Again, thank you all very much. Additional ideas always welcome.
As we try something and it doesn't work, this gives us additional ideas to continue working with.
Unread 13-01-2013, 20:14
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
We prototyped a hook out of 1/4" 6061 aluminum plate, it easily supported a robot equivalent of weight.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 13-01-2013, 20:41
EricH EricH is online now
Modify a climbing carabiner, large size, by removing the gate or the locking mechanism of the gate (depending on whether you want to lock onto the bar or use the hook elsewhere). I've seen teams lift robots with them before. If they can hold a 200lb human, they should be able to hold a 150lb robot--just make sure you get one rated for that weight.
As an added bonus, they're not going to be terribly expensive.
Unread 13-01-2013, 21:07
Phyrxes's Avatar
AKA: Dave Button
Carabiners are traditionally rated in kN (approximately 225 lbs). The ratings are specific along the different parts of the carabiner, if you are going this route talk to your local outdoor store and see what they have.
Dave Button
Wakefield School
The Plains, VA
