Go to Post Robot: Aww, the FMS doesn't want to chat with me anymore. Was it something I said? - EricVanWyk [more]
Unread 12-01-2013, 23:28
PizzaBoxZombie's Avatar
PizzaBoxZombie PizzaBoxZombie is offline
FRC #0225 (Tech Fire)
PizzaBoxZombie has much to be proud ofPizzaBoxZombie has much to be proud ofPizzaBoxZombie has much to be proud ofPizzaBoxZombie has much to be proud ofPizzaBoxZombie has much to be proud ofPizzaBoxZombie has much to be proud ofPizzaBoxZombie has much to be proud ofPizzaBoxZombie has much to be proud ofPizzaBoxZombie has much to be proud ofPizzaBoxZombie has much to be proud of
Andymark Pneumatic wheel problems
As several other teams and IR3 have shown in various youtube videos, the pneumatic wheels from andymark are pretty decent shooting wheels. after recieving ours, however, we found that ours are out of balance/round. spinning at 5-6500 rpm they shake around a lot and can not achieve full potential speed.
we have since changed wheels for some more consistent and faster, but we were wondering if anyone else had tried to use them and found the same problems? and if anyone has, have you found a solution?
Unread 12-01-2013, 23:31
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Andymark Pneumatic wheel problems
We definitely have had the same issues, we haven't found a solution and moved on to other options.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 12-01-2013, 23:39
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Is the tire bead seated correctly?
Unread 12-01-2013, 23:46
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
That's the problem. We can't get it to seat correctly. Any tips/tricks to do so?
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 12-01-2013, 23:55
yeah, ours were, to the best we could figure out, ill double check. thanks. the other problem was we still had to balance the valve stem.
Unread 13-01-2013, 01:05
Tyfighter98's Avatar
Tyfighter98 Tyfighter98 is offline
Software Lead
FRC #3255 (Super NURDs)
Tyfighter98 is an unknown quantity at this point
I believe I was experiencing that same problem today when we were testing a prototype. The pneumatic wheels appeared to have a lot of free movement. I don't know if this is just our prototype or wether the wheel isn't seated properly.
Unread 13-01-2013, 09:00
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
I believe the problem is with your speed and not the wheels. If I remember correctly, IR3 only used a cim at ~55% power.
Unread 13-01-2013, 17:58
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
Is there a special method in order to seat the wheel?
Unread 13-01-2013, 18:02
I'm trying to hunt down the source for this. Do you remember where you got it?
Unread 13-01-2013, 18:03
Best Available Data
FRC #1778 (Chill Out!)
I doubt Andy & Mark expected teams to try and go 125 mph with those wheels. As others have said slowing down or switching is probably the least work per performance.
Unread 13-01-2013, 21:12
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
We tested our pneumatic wheel at 60% speed today, launching between the wheel and our wood prototype base. We experienced approximately the same range/speed as the Robot in Three Days robot.
Unread 13-01-2013, 21:17
Andrew Zeller's Avatar
Andrew Zeller Andrew Zeller is offline
Mechanical Engineering at UA
FRC #1716 (Redbird Robotics)
Andrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura about
60% of CIM free speed?
FIRST ROBOTICS TEAM 1716 Redbird Robotics
2012 Wisconsin Regional Judges Award
2012 Wisconsin Regional Quarterfinalists
http://www.frc1716.org/
Unread 13-01-2013, 21:18
Oldbikerider's Avatar
Oldbikerider Oldbikerider is offline
AKA: Graham
FRC #3132 (Thunder Down Under)
Oldbikerider will become famous soon enough
On a related question, does anyone know what the safe working speed is with the AndyMark wheels? I've searched but can't find anything. I'm thinking that some bursting strength calculations are necessary here.
We've been testing with some 10 inch OD "highway" treaded mobility scooter tires mounted on 4 inch go-kart wheels. At 1600rpm there is significant tread growth and they start to get unstable in balance. The two wheels also appear to feed vibrations to each other in complex ways.
I wonder what actually fails first. Would the tire tread just catastrophically fail, or would bits start shedding more gently? I suspect the former.
Graham.
Unread 13-01-2013, 21:22
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
Just to bring up a couple of other possible issues...
Are the bearings installed properly (with flanges and such extremely level and tightly in place)?
Are you using a cantilevered or secured method for the wheel?
I would guess that if you could have a bearing or some other type of "reciever" for the end of the shaft, you may take some of the wiggle out of it. I do agree with some posts above that I doubt these wheels are really meant to spin as fast as many teams are spinning them. More then likely, that is the main issue, but I wanted to just bring up a couple of other possible issues.
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
I can't promise that, we coded eleven buttons to control the speed. Button 1 was 10%, 2 -> 20% etc. We ran it on buttons 6 and 7.
I uploaded a video of our shooter at 1000 frames/sec http://youtu.be/7dN1thFqr7k
