Go to Post A few months from now I'll be walking to school and then I'll suddenly be attack by a rogue robot trying to feed me a golden ball or something wont I? - Marcel [more]
Unread 12-01-2013, 21:06
Best Available Data
FRC #1778 (Chill Out!)
Re: Shooter Problem
Originally Posted by DonRotolo View Post
The Plexiglas arc may be too slippery, and the frisbee is slipping instead of rolling along. You may want to add something soft and squishy there, like foam tape.
Having played with a similar setup this is almost certainly the problem. Gaffer's tape on the arc worked really well, if you don't have any of that masking tape would probably work about as well. We're going to try hockey tape tomorrow.
Unread 12-01-2013, 21:10
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Shooter Problem
We have plans to try several of the tricks mentioned here, and we'll try to report back with our findings.
Unread 12-01-2013, 22:39
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Re: Shooter Problem
Check and make sure the wheel is tighten to the axle and is not slipping
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 12-01-2013, 22:43
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: Shooter Problem
We found tread material to give us the most difference in performance. We use wedgetop wheel tread and it works well on a 6 inch wheel.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 12-01-2013, 23:05
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Shooter Problem
Originally Posted by ThePlagueDoctor View Post
The frisbee rolls and moves in the shooter just fine, its just that it doesn't launch that far, barely at all...
OK, let's say it is slipping 90% - you would never be able to see this with your 'bare eyes'.
As Ian Curtis mentioned, try some tape on the plexi. Then come back and tell me it didn't work, But not before you try it, all right?
Unread 13-01-2013, 10:09
MrForbes's Avatar
AKA: Jim
Re: Shooter Problem
This is what we're planning to try tomorrow. And we'll set it up so we can play with the speeds, by using chain drive and computer speed control, eventually with a PID loop of some type.
Unread 13-01-2013, 11:48
ThePlagueDoctor's Avatar
ThePlagueDoctor ThePlagueDoctor is offline
ArduinoFTW
AKA: Anthony
FRC #0375 (The Robotic Plague)
ThePlagueDoctor is an unknown quantity at this point
Re: Shooter Problem
That gives you a lot of headroom to do closed-loop speed control. A bang-bang controller probably will work very well.
Also, interested in your answer to Aroki's questions about the gearing and the wheel.
We are using a 8 inch high grip wheel directly driven with a cim
Just remember, if a plague comes out of no where.... Well you know where it came from
<a href="http://www.thebluealliance.net/tbatv/team/375" style="border: 0"><img src="http://www.thebluealliance.net/tbatv/teambadge/gen/375/000000/FFCC00/teambadge.png" alt="Team 375" /></a>
Unread 13-01-2013, 15:00
Re: Shooter Problem
Try P-only and crank the gain up to the sky*. If you've got enough inertia in the wheel, and you run the loop at 10ms, that's all the tuning you should need.
* this will mimic a bang-bang controller.
Unread 13-01-2013, 20:50
Dinoyan Dinoyan is offline
Team Role: Electrical
Dinoyan is an unknown quantity at this point
Re: Shooter Problem
We know how we're going to shoot but how we're going to put the frisbees in to the robot or how will the robot going to pick it up????.
Unread 14-01-2013, 01:54
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Re: Shooter Problem
Yeah, I'd say that you might want to go with a bang-bang controller.
If you get flack from your mechanical/fabricators for "slamming" the motor, do what I did, add a linear cushion within ~3% of your target speed.
Ex. For a shooter wheel capable of 10,000RPM when you're over 300 RPM lower than your setpoint, you go 100% power, when you're 150 RPM Lower, 75%, Dead on 50%, 150RPM Higher 25%, 300RPM Higher 0%.
This will mimic the PID you're trying to use, and unless you really know what you're doing when PID tuning, will be half the headache.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 14-01-2013, 11:09
Re: Shooter Problem
Originally Posted by Woolly View Post
If you get flack from your mechanical/fabricators for "slamming" the motor...
Seriously? Are you saying there was some visible or audible manifestation?
If so, check the following and fix if necessary:
- make sure the motor controller jumper is in the "coast" position (not "brake").
- make sure you are running the control loop fast enough (10 ms is good)
- make sure your sensor is capable of giving an up-to-date speed reading faster than your control loop iteration rate
Unread 14-01-2013, 15:34
Woolly's Avatar
Programming Mentor
Re: Shooter Problem
I didn't know what I know now when I made that control loop last year, and I just dropped it in autonomous and teleop. Obviously a case of it not running fast enough. Still, even our poor bang-bang controller was better than a PID for this application.
