Go to Post The more interesting arguments were around a related subject: whether it was pronounced "Wago tool" or "screwdriver". - Billfred [more]
Unread 01-13-2013, 01:30 PM
AsianSensation AsianSensation is offline
Programmer, Driver
AKA: Jerry L
FRC #4203 (RoboKronos)
AsianSensation is an unknown quantity at this point
How to program command based robot
Ok, before you go to your bookmarks or whatever to pull out the WPI getting started with FRC Java pdf, the WPIcookbook pdf, and WPI robotics library user guide pdf, read the question please.
I was following the instructions in the WPIcookbook for the command based robot, but it is still giving me errors saying either a class doesn't exist or the method doesn't exist...am I missing something from the cookbook or did they leave out some parts (like imports and such)?
Unread 01-13-2013, 01:31 PM
Re: How to program command based robot
If you copy and paste the complete error and/or post your code it would likely be easier to assist with your question.
Unread 01-13-2013, 02:44 PM
This is not the ideal way to endear yourself to those from whom you are seeking assistance.
Unread 01-13-2013, 09:51 PM
Johnbot's Avatar
Johnbot Johnbot is offline
Es Brokein!
AKA: John Westhoff
FRC #4791 (Pandroids)
Johnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really nice
I do believe that the cookbook leaves out imports, which you can very easily fix.
Assuming you have the Netbeans plugins installed, just right-click the editor, and click "Fix Imports."
If that isn't your problem, then you should post your entire error message.
2011-2014 - FRC 2607 - Student
2012-2012 - FLL 2249 - Coach
2015- ???? - FRC 4791 - Mentor
Unread 01-14-2013, 08:09 PM
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
You can also press CTRL+SHIFT+I on Windows to automatically do this. Of course, that assumes the problem is with imports in the first place.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
