Go to Post There's no finer engineering than pit engineering. - kaszeta [more]
Unread 13-01-2013, 13:54
Iaquinto.Joe's Avatar
Iaquinto.Joe Iaquinto.Joe is offline
RPI 2018
AKA: Joe Iaquinto
FRC #0308 (The Monsters)
Iaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the rough
Question Building two bots
Our team (308) is building two identical robots this year. We are going to use the second bot to practice, develop a 30 point climb (Potentially), and develop code and autonomous code. We're aiming to be done ~week 5 and perfecting everything week 6.
What other teams are doing the same? Any veterans have tips and tricks on keeping them the same?
Unread 13-01-2013, 13:57
Koko Ed's Avatar
Koko Ed Koko Ed is online now
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: Building two bots
Since 2005 we have been building two bots. We first build the prototype'practice bot first (we aim to have it done by week two but often it's finished by week four) and we take everything we learned building the prototype (and learn from our mistakes)to build the competition bot .
Unread 13-01-2013, 14:08
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
We are also building two bots; one is shooter/10 point climber, the other a dedicated 30 point climber with potential TBD to score the 5 point discs. It is a lot of fun, and when they are completed (hopefully by the end of week 3) we will test scoring options to determine which one to take to competition.
Unread 13-01-2013, 14:12
reymac's Avatar
reymac reymac is offline
FRC #0073 (Visioneers)
reymac is an unknown quantity at this point
Team 73 is building two bots as well this year for similar reasons that Ed mentioned.
My only worry is that you guys are aiming for week 5. To get two useful bots done (an oops bot and a competition bot) done, I would aim for week 3. That way you can practice with one bot and start building your competition bot simultaneously. Week 5 is just too late in my book, it leaves no time to order parts (a lot of things are out of stock by then) or fix any problems that will come up.
Corey Mack
Team Leader
Team 73: The Illumination
Unread 13-01-2013, 14:21
RPI 2018
AKA: Joe Iaquinto
One of the main problems is that we only meet 3-4 times a week for 4-5 hours each time. The team leaders want the entire robot in CAD but we don't have that nailed down yet. We need to kick it into overdrive I think. Personally, i'm on the programming team and we have very little completed. Drive train code is finished (Reused 2011 code) and dashboard is nearly functional. We're looking to get vision done by next Saturday but finals are this week so...
4 year 2011 - 2014 FRC team 308 member, Lead Programmer - C++ / LabVIEW
3 year 2011, 2013, 2014 OCCRA member, Co-Captain OCCRA team 308
  • OCCRA Engineering Excellence - Waterford Kettering 2013
  • Innovation in Control - 2011
  • Quality award- Northville 2012
  • Engineering Excellence- Howell 2014
  • Innovation in Controls- Livonia 2014
Unread 13-01-2013, 14:25
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Next year when you have the practice bot in your possession you will be able to make the process more efficient.
Unread 13-01-2013, 14:31
reymac's Avatar
Hmm...You are right. You guys need to kick it into overdrive. Coding is typically not the most time consuming part since you don't need to code when the whole team meets. But you need to talk with your team's leader and remind him/her that time's ticking.
If you guys aren't a very focused group, you may need to just do one robot and get students "behind the wheel". If my choices were two robots and no practice time or one robot with practice time, I'd pick the latter.
Corey Mack
Team Leader
Unread 13-01-2013, 18:16
kingbrandon14's Avatar
kingbrandon14 kingbrandon14 is offline
FRC 4188 Engineering Mentor
AKA: Brandon King
FRC #4188 (Columbus Space Program)
kingbrandon14 will become famous soon enough
My team is building 2 robots for the first time this year, but we are taking a different approach than usual. Instead of having 2 identical robots, we are building 2 slightly different robots, and choosing the better of the 2 to go to competition with. We will then use the 2nd one to practice between bag-day and competition. We are planning to be able to shoot 3 point shots, as well as climb to the third level.
2012 Peachtree Regional Rookie All-Star; 2015 Peachtree Regional Winner; 2016 PCH District Columbus Winner, Albany Finalist & EI; 2016 Rocket City Regional Finalist, Wildcard
Unread 13-01-2013, 19:58
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Our team is aiming to build 2 robots this year. While this is my first time attempting to do so, one of our other mentors has years of experience building two robots and scheduling time appropriately so. We've already started cutting out enough parts for 2 chassis. One of the chassis will be going to the programmers for refining drive code and the vision targeting. The other robot will be the practice robot, and will have the first iteration of designed parts on it. We'll produce a 2nd iteration of parts that fix any problems with the first iteration, and this will go on the final robot, which the programmers will have been working on until that point. We aim to have both done by week 6, and have the practice bot be used for constant practice and refining for our week 1 and week 3 events.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 13-01-2013, 20:13
Chris C. 2410 Chris C. 2410 is offline
FRC #2410
Chris C. 2410 is an unknown quantity at this point
We are planning 2 bots as well. Withholding design specifics, I can say that our goal is to build our first and improve it, rebuilding as we go. Once we know what works, we will finalize 1 and then build an exact copy to practice with. Additionally, we will most likely practice asking the second one as well as our older bots.
Unread 13-01-2013, 21:02
AdamHeard's Avatar
Lead Mentor
Why stop at two?
Unread 13-01-2013, 21:10
Alex.q Alex.q is offline
FRC #2220 (Blue Twilight)
Alex.q is on a distinguished road
Why stop at two?
Mostly for my team this year, money was the limiting factor. We have nearly 80 kids on the team now (I think this may include the FTC kids too though), so we have subteams on drivetrain, 2 subteams on frisbee manipulators, and 2 subteams on climbing manipulators. Each manipulator group will prototype a different type of mechanism, (linear vs circular shooter and 1st tier vs 3rd tier climber) and when they finish, they will decide which work best and redesign and build for version 2. This is the first year where we have had teams competing against each other for the design, so I'm not sure how it will work out. I think their original goal was to have 3 robots, but we just didn't have the budget.
Unread 13-01-2013, 21:38
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
We are planning on building 2 bots. The practice bot comes first and any mistakes in the design get fixed and the 2nd bot is created with the fixes for competition. We are looking at completing of bot 1 by week 4 and the 2nd one will come easier.
461 Westside Boiler Invasion
45 Technokats
Unread 13-01-2013, 22:30
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Why stop at two?
Please don't tell me 973 will have 2+ robots this year.
Unread 13-01-2013, 22:54
hunterteam3476's Avatar
hunterteam3476 hunterteam3476 is offline
AKA: Hunter
FRC #3476 (Code Orange)
hunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud of
Smile Re: Building two bots
3476 code orange is making 2 robots, so that we can practice with one before competition and in between competitions
