Go to Post For me, this is the most powerful message of FIRST, that people can come together and work together to achieve so much, and leave old rivalries, grudges, and hard feelings behind. When people talk about culture change, this is what I hope for. - Aren Siekmeier [more]
Unread 13-01-2013, 00:31
William Kunkel William Kunkel is offline
Programming Lead
AKA: Kunkel
FRC #0422 (Mech Tech Dragons)
William Kunkel is an unknown quantity at this point
Remove FRC Default Dashboard Window Decoration
When starting up the FRC default dashboard on our newly-reimaged classmate E09, (i.e. by logging into the Driver account), the dashboard retains window decoration. That is, the title bar, buttons, and border for the top half of our driver station are visible. This has the rather annoying-side effect of clipping the bottom of the window, because it can no longer fit in the space. Has anyone else experienced this, and/or have a fix for it?
Unread 13-01-2013, 10:40
Re: Remove FRC Default Dashboard Window Decoration
The Dashboard should lose it's frame when you dock the Driver Station.
Unread 13-01-2013, 11:10
Programming Lead
AKA: Kunkel
You mean, change the windowing mode so that it snaps to the corner? Because the required driver station is already snapped to the corner, and the option to change the windowing mode is greyed-out.
Unread 13-01-2013, 12:16
Try using the developer account and snapping the Driver Station there.
The two windows should fill the screen as they used to in the Driver account.
You'll need to hide the Windows taskbar to have i all fit properly.
Unread 13-01-2013, 15:12
Programming Lead
AKA: Kunkel
We can certainly deal with the clipping if we had to, it's just obnoxious. I'd like to be able to get it working as intended for the Driver account, as the software behaves differently when running under the user "Driver", e.g. it logs out automatically when the driver station is closed.
Unread 13-01-2013, 15:14
Then you can do it yourself by creating a new Dashboard project and always forcing the removal of the window borders.
Or test for "Driver" account.
The code is all there.
Unread 13-01-2013, 21:01
This is what we had to do today. It worked after that in Driver.
Unread 18-01-2013, 19:54
Rollie Rollie is offline
FRC #1760
Rollie is an unknown quantity at this point
We ran into the same problem after updating the Driver Station on our Classmate for 2013. We found that we just needed to locate and edit our "FRC DS Data Storage.ini" file and change the "Moveablewindow" property from TRUE to FALSE. Once we did this, the dashboard displayed without the frame when we logged in under the Driver account. The ini file was located in C:\Users\Public\Public Documents\FRC on our Classmate.
