Go to Post While [a college FIRST competition] would be pretty fun, I think that you'll see this build season that mentoring is a heck of a lot of fun too. (except when the kids pretend to cut their fingers off to see your reaction) - Beth Sweet [more]
Unread 12-01-2013, 14:01
PyroKnight PyroKnight is offline
FRC #0696
Team Role: Animator
PyroKnight is an unknown quantity at this point
Question How to attach a metal hook to a timing belt.
Hi, our team is trying to attach a type of hook on to a timing belt without using glue (in our testing it proved too weak). It needs to be able to go around the belt as this will be constantly revolving around and pushing frisbees but it cannot be fastened from the bottom. We'd appreciate any suggestions, thank you.
Unread 12-01-2013, 14:25
nnfuller's Avatar
nnfuller nnfuller is offline
AKA: Alumni
FRC #2733 (Pigmice)
nnfuller is on a distinguished road
Re: How to attach a metal hook to a timing belt.
Do you need to use timing belts? Have you considered alternatives? I know for a while my team was considering these and #35 chain http://www.mcmaster.com/#catalog/118/1036/=l08izr
heavier yes, but far more robust. Anyone else have any ideas?
Unread 12-01-2013, 14:31
FRC #0696
Team Role: Animator
This looks interesting, definitely a consideration, more ideas along these lines wouldn't be bad. Thanks for the suggestion.
Unread 12-01-2013, 19:12
DonRotolo's Avatar
Back to humble
FRC #0832
Perhaps a pop rivet would work
Unread 12-01-2013, 19:52
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
If all your pulleys are big enough that a pop rivet head won't throw your belt, I can see that working. You definitely want the head on the toothed side of the belt, though.
Unread 12-01-2013, 20:11
mdiradoorian mdiradoorian is offline
FIRST Alum
AKA: Matthew
FRC #0696 (CircuitBreakers)
mdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant future
Guys you can't use a pop rivet on a timing belt considering that there are grooves on the inside of the belt to the pulleys. I like the idea with the chain because it does not break and is a rigid structure.
Unread 12-01-2013, 20:33
Aroki's Avatar
Aroki Aroki is offline
FRC #1787 (Flying Circuits)
Team Role: CAD
Aroki will become famous soon enoughAroki will become famous soon enough
Could you explain what the timing belt-hook with be used for? It's a bit challenging to suggest solutions without any idea of the constraints
Unread 12-01-2013, 20:35
FIRST Alum
AKA: Matthew
It would be used for a floor pickup mechanism. It would be after the floor pickup to the magazine. Also it would be used from the magazine to the shooter.
Unread 12-01-2013, 20:47
Aroki's Avatar
Team Role: CAD
I would avoid floor pickup, (in my opinion at least) the advantage of being able to pick up from the floor is less than the difficulty of designing a mechanism that picks up and can also orient the frisbees, and the time spent doing that would be better spent making a good climber and/or a reliable shooter/loader robot. This also removes the need for a floor pickup to magazine mechanism
In regards to the magazine to shooter, I'd suggest:
1. Conveyor belt under the magazine made from surgical tubing or timing belts (with the teeth pointing outwards).
2. A motor with a bar that rotates around and each time pushes out the bottom frisbee into the shooter
3. A piston behind the magazine that pushes the frisbees out into the shooter
Unread 12-01-2013, 20:55
FIRST Alum
AKA: Matthew
We actually do have a system on orienting the discs, however when still need to figure out how the discs will move with our system. The chain idea i so far the better option Thanks nnfuller.
Unread 12-01-2013, 23:09
DonRotolo's Avatar
Back to humble
FRC #0832
Yes, of course, there is no way to modify the rivet head to make this work. Silly me.
Unread 12-01-2013, 23:42
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Shoe Goo urethane adhesive will hold the hooks on, as long as you give it time to fully cure 48 hours. It has super tenacious grip and very high peel strength.
It also remains flexible after curing. so it can handle the flex of going around the pulleys, as long as they aren't super small dia.
If you want a thick coat, put it on in two applications, allowing 1st one 24 hours cure time before applying the second. If laid on too thickly. lowest level curing gets delayed from so much more piled on top of it. It cures by out-gassing volatiles, so keep in a well ventilated area during curing.
To check if it's done curing, just smell it. Stink means not done yet.
Sticks to most everything, as long as surface is fully cleaned.
Best all around glue you can buy.
I build custom roller skates gluing the skate plates onto carbonfibre reinforced soles of athletic shoes (no screws), and have skated one outdoor pair for 13 years with no glue joint separation.
Example: glue mounted indoor speed skates -
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
Unread 13-01-2013, 16:04
FIRST Alum
AKA: Matthew
By having this glue on the timing belt wouldn't it break off the belt considering the repetitious bend when it comes to the pulley?
Unread 13-01-2013, 16:17
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Originally Posted by RRLedford View Post
Shoe Goo urethane...
+1. Or I found a glue called "E6000". I think it might have a bit more strength, but stays flexible too.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 13-01-2013, 16:19
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
If you still like belts, what's stopping you from grooving the pulley to allow a fastener to pass through? All it takes is a lathe and a little patience. You shouldn't need the full width of the pulley to grip the belt if it is just lifting the weight of a frisbee.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
