Go to Post Tom didn't need the t-shirt to tell us [that he is a NERD] :D - Peter Matteson [more]
Unread 13-01-2013, 17:51
mdiradoorian mdiradoorian is offline
FIRST Alum
AKA: Matthew
FRC #0696 (CircuitBreakers)
mdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant future
Re: How to attach a metal hook to a timing belt.
Originally Posted by Jeffy View Post
+1. Or I found a glue called "E6000". I think it might have a bit more strength, but stays flexible too.
Here is the link for the glue and thank you http://www.michaels.com/E-6000%C2%AE...efault,pd.html
Originally Posted by MrBasse View Post
If you still like belts, what's stopping you from grooving the pulley to allow a fastener to pass through? All it takes is a lathe and a little patience. You shouldn't need the full width of the pulley to grip the belt if it is just lifting the weight of a frisbee.
that is true, however I want a system to be simple, easy to make and easy to repair if it breaks.
