#16
Re: How to attach a metal hook to a timing belt.
What isn't simple to repair? You would effectively cut the teeth off the pulley in the center. So if you used a fastener with a .25 head on it, cut a quarter inch groove in the middle of the pulley teeth. The only thing that might fail would be a fastener and those are pretty easy to come by. |
#18
Oh by the way putting a fastener in the middle of a timing belt would increase the chances of of the belt breaking even if i were to make a groove in the middle of the pulley. The reason how I know is that I have tried. By having a belt you need tension and tension stretches to belt and when you stretch the belt with a hole in the middle of it increases the chances of it tearing.
#19
A belt tearing is very dependent on the stress levels we are talking about. I'd hope hat there aren't a lot of forces involved in a frisbee conveyor, otherwise I would question the overall design.
#20
An alternative to lathing a slot in the pulley would be to obtain a non-flanged pulley whose width is smaller than the belt width. You could then fasten the hooks to the edges of the belts. You would, however, have to consider how to keep the belt centered on that non-flanged pulley.
#21
I use E6000 at work. It has a little more strength then "Super Glue", but not much more.
#22
A robot which sacrifices a complex hanger in lieu of a good autonomous which nets the 4 floor discs into the high goal is more valuable than a robot which sacrifices floor pickup for a 30-point hang. (24-pt auton from floor + 10-pt hang > 30-pt hang). That said, a 6-7 disc autonomous is just as hard (IMO) as a 30-point hang, and only one robot on an alliance is eligible to pickup 4 discs in a single auton. Yet the point is that there's a very good case for pickup from the floor for 2 robots on an alliance. There's also good discussion about whether there will even BE any upside-down discs. (edit -- sorry for the thread hijack -- the OP should keep trying with their floor pickup endeavors, IMO) Last edited by JesseK : 13-01-2013 at 20:58. |
