Go to Post Man, I never thought I'd have to cite a rule during the offseason. - Karibou [more]
Unread 13-01-2013, 20:24
Re: Programming ultrasonic rangefinders
Getting input from a PWM signal is one thing that I've never found a good way to handle using the available hardware and software of an FRC robot. You can play around with using a filter circuit to turn the signal into an analog voltage and read it that way, but it would take a lot less time to move the output wire to the voltage pin of the sensor.
