Go to Post I swear, sometimes it seems like FIRST has got a room full of monkeys writing code. Maybe the monkeys should spend less time flinging fecal matter at each other and more time testing the code before posting it :-). - Kevin Watson [more]
Unread 13-01-2013, 19:45
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
Re: 2 wheels vs 1 wheel in a linear shooter
Originally Posted by Oldbikerider View Post
We're hoping two are sufficient. Our tests indicate that it can probably be done with two.
I also question why a speed differential is needed. Why not just impart as much energy as you can with each wheel? We're not looking to maximize efficiency here, just fire discs as fast as possible. What is wrong if the first wheel got the disc to near full speed, then the second wheel doesn't have to do much more.
Graham.
By that logic why would you need a second wheel if you're attempting to impart as much energy as possible with the first wheel? As stated, the idea behind the two wheel shooter is because of the contact time between discs and wheels. If you use the first wheel to accelerate the disc and the second to propel the disc, you get comparable results to a circular shooter.
Academic Student (Forever)
Unread 13-01-2013, 20:03
I didn't say it was "needed". I was speculating that you can squeeze more performance from a given shooter by doing so.
If that's your goal, then the first wheel should be driven slower than the second.
There's a wheel speed above which the exit velocity of the frisbee from that wheel actually starts decreasing, presumably due to excessive slipping. The first wheel reaches this point before the second one does because the frisbee speed coming into the first wheel is so much slower than for the second wheel.
Unread 13-01-2013, 20:05
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
I think if you can control the speed of the 1st wheel from like 40% to 75% of the second wheel, you can also effectively control the distance. Am I correct?
Faridodin "Fredi" Lajvardi KD7WKD
Unread 13-01-2013, 20:07
The second wheel probably has more effect on the exit speed.
Unread 13-01-2013, 20:13
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
May I suggest the following equality:
sum("wheels") from 1 to infinity = "belt"
I know it's not really the same, but still.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 13-01-2013, 20:16
Oldbikerider's Avatar
Oldbikerider Oldbikerider is offline
AKA: Graham
FRC #3132 (Thunder Down Under)
Oldbikerider will become famous soon enough
Our tests would indicate that one wheel is not enough. Some things to consider are how much compression is needed to impart enough speed to the disc, and how that compression effects the disc and it's trajectory.
I'm questioning why it's necessary to second guess how much each wheel will add, and why it would be necessary to have different wheel speeds for the first and second wheel. What's wrong with running both wheels at full speed. Maybe under ideal conditions, perfectly round and clean and dry disc, full speed is achieved with the first wheel, but maybe under less than ideal conditions the second wheel is needed. Under some circumstances the second wheel is just insurance.
Graham.
Unread 13-01-2013, 20:39
You said in your earlier post that your goal was to "fire discs as fast as possible".
I interpreted this to mean "with the fastest exit velocity achievable with a given 2-wheel linear shooter" .
If that is the correct interpretation of your post, then you would want to get the maximum speed increase (change in speed) as the frisbee passes through each wheel.
Based on tests run by Team 2073, this would indicate that the second wheel should be run at a faster speed than the first, to achieve your goal.
Unread 13-01-2013, 20:52
Dinoyan Dinoyan is offline
Team Role: Electrical
Dinoyan is an unknown quantity at this point
2 wheel linear shooter make your frisbees to go further
Unread 13-01-2013, 21:03
Andrew Zeller's Avatar
Andrew Zeller Andrew Zeller is offline
Mechanical Engineering at UA
FRC #1716 (Redbird Robotics)
Andrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura about
With 2 wheels, the maximum frisbee speed is still half the wheel tangential velocity.
I also followed your math here:
It translates into approx 21 mph, assuming no slipping.
3600 rpm / 60 min/sec = 60 rev/sec
60 rev/sec * pi*4/12 ft/rev = 62.8 ft/sec
62.8 ft/sec / 2 = 31.4 ft/sec
31.4 ft/sec * 3600 sec/hour / 5280 ft/mile = 21.4 mph
I understand that the rotation of the frisbee as it contacts the wheel causes less than its full velocity to be transferred in an ideal situation, however why is it that the maximum exit velocity of the frisbee will theoretically be one half that of the tangential velocity of the wheel?
FIRST ROBOTICS TEAM 1716 Redbird Robotics
2012 Wisconsin Regional Judges Award
2012 Wisconsin Regional Quarterfinalists
http://www.frc1716.org/
Unread 13-01-2013, 21:08
AKA: Graham
Ether,
Yes, I said "firing discs as fast as possible", but there are some upper limits here.
There is evidence indicating that too much compression leads to distorting the disc, with adverse effects on the accuracy of shot, and people are also reporting a plateauing of the achievable disc exit speed where an increase in wheel speed does not result in a proportional increase in exit speed.
So, my thinking is that yes, doing the firing in two (or maybe three) milder steps is the way to go, but I take your point that if the first wheel got the speed then why add a second wheel. My reasoning is that the second wheel simply makes sure the speed is correct, adding something extra in the case of a dirty or warped disc, but not adding any more speed in other more ideal circumstances. I'm concerned more about consistency.
Graham.
Unread 13-01-2013, 21:23
Think of a car traveling down the highway at 60 mph.
The geometrical center of each tire is traveling at 60 mph.
At any instant in time, the bottom of each tire is traveling at 0 mph, and the top of each tire is traveling at 120 mph.
It's the same with the frisbee.
Unread 13-01-2013, 21:30
Unbound's Avatar
Unbound Unbound is offline
Certified Cable Tie Technician
AKA: Fillazar
FRC #2443 (Blue Thunder)
Unbound is infamous around these partsUnbound is infamous around these parts
We are using two wheels in our shooter one to give the disk a spin and the other to propel the disk forward.
Just for the record, that was someone else's point, not mine.
Unread 13-01-2013, 21:32
How does the first wheel spin the frisbee without propelling it forward?
And how does the second wheel propel the frisbee forward without adding additional spin?
Could you post a picture?
Unread 13-01-2013, 21:58
Makes sense - thanks for the explanation.
