Re: Where can I find anderson power connector with acceptable minimum quantity
Do you mean these? You should know that both SB50s and the PP series are commonly used in FRC, although only the SB50 is required.
As a note: make sure you buy red SB50s. We learned the hard way that gray SB50s don't plug into red SB50s. |
