Go to Post wow Paul and Rich in a photograph, i thought that if that much nerd got together that a black hole would form - Mike Schroeder [more]
Unread 13-01-2013, 21:19
awkwardbunny awkwardbunny is offline
AKA: Brian Hong
FRC #1155 (SciBorgs)
awkwardbunny is an unknown quantity at this point
Axis Camera "No image available"
Ok so last couple if days my partner and I have been trying to get our test bot to work and we updated everything, including the dashboard. Now, we have the pc, the crio, and the camera all connected to the router with default addresses.(10.xx.yy.11 for camera) on the 2013 dashboard, the data transfer and the fps shows but we get no image. Also, when we call the .getImage() method from the camera.getInstance(), we get an AxisCameraException with message "No Image available". This error also happened with the 2012 version, which showed the image on the dash board. Help...?
Unread 13-01-2013, 21:20
Johnbot's Avatar
Johnbot Johnbot is offline
Es Brokein!
AKA: John Westhoff
FRC #4791 (Pandroids)
Johnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really nice
Re: Axis Camera "No image available"
Did you enable anonymous viewing in the cameras webpage?
2011-2014 - FRC 2607 - Student
2012-2012 - FLL 2249 - Coach
2015- ???? - FRC 4791 - Mentor
Unread 13-01-2013, 21:33
AKA: Brian Hong
I did try enabling anonymous mode and also tried setting the username and pass to FRC
The frame rate and data transfer shows so doesnt that mean it's configured correctly?
Unread 13-01-2013, 23:28
cal3d cal3d is offline
FRC #0467 (Shrewsbury Colonials)
cal3d is an unknown quantity at this point
We had the same problem. It turned out that the programmer who updated our classmate didn't follow the instructions correctly.
If you simply install the new software over the old software then the camera doesn't show. You have to completely remove the old NI software from last year using the uninstall option as shown in the instructions - before installing any of the new driverstation software.
Unread 14-01-2013, 07:02
AKA: Brian Hong
Will do try that. Thank you
