Go to Post everyone in FIRST has to do the cha cha slide at least once per season to get it out of their system. Now I can go back to doing it in the privacy of my own car (if you see a red Jeep in CT swerving back and forth don't worry, it's just me doing the slide...)! - KathieK [more]
Unread 13-01-2013, 22:36
divixsoft's Avatar
divixsoft divixsoft is offline
FRC #0835
divixsoft is an unknown quantity at this point
Re: Onboard Computer
Thanks for such fast replies. So what you are saying is I can have the highest quality image I want sent to the on board computer. Then send smaller images to the driverstation?
If so, how would the network setup work, in detail please I do not know that much about networking.
Thanks a ton,
Dimitri
Unread 14-01-2013, 12:00
The networking is pretty simple. The cRIO, Camera, and on-board computer should all connect to the radio. Give the on-board computer a static IP address of 10.xx.yy.12 (or another unused IP address).
Unread 15-01-2013, 20:16
divixsoft's Avatar
FRC #0835
Thanks for the reply, but how would you suggest I set this up:
Robot Camera takes the picture then sends it to the onboard computer, the onboard computer processes it, than sends values back to the robot. I know how to do these parts, but I am not sure how to communicate between driver stations. I want to be able to set which target to search for from the driver station to the onboard computer. Also how could I send coordinates from the onboard computer to the driver station, to draw on the driverstation feed?
thanks
Dimitri
Unread 16-01-2013, 07:44
Use SmartDashboard variables. If each of the devices you mention speaks the SmartDashboard protocol, the values are kept in shared and kept in sync. In what you describe, you have SmartDashboard on the dashboard, robot, and imaging card.
Greg McKaskle
Unread 16-01-2013, 20:19
divixsoft's Avatar
FRC #0835
What are smartdashboard variables, and does anyone have any experience with robotrealm?
thanks,
Dimitri
