Go to Post I wonder if it could be... Nah, that would just be way too... Never mind. . - dlavery [more]
Unread 13-01-2013, 23:16
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Wheel Types: What's best, and why?
Hey all.
I don't know if I missed it, but I didn't see a thread specifically made to address wheel types and their effect on shooters. I've seen threads for single wheels (pneumatic, etc) but not to bring a whole discussion to it.
What type of wheels seem to work best? (Pneumatic, performance w/ tread, treaded KOP wheels (2012 or 2013), 2008 KOP wheels (gray rigid ones) or something else?
Also, why do you think this is?
On our side, the 2008 KOP wheel seems to be delivering sad results. I've seen teams use the 2012/13 KOP wheels with great success, and I'm having trouble figuring out why.
We thought 2008 ones worked poorly because they were rigid and not compressible - however, the 2012/13 ones are rigid as well, yet seem to work well on a variety of launchers.
Thoughts?
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 13-01-2013, 23:38
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Wheel Types: What's best, and why?
2010 wheels work fine when implemented correctly (I might have a video) but they are much less accurate then the pneumatic wheels.
The 2010 wheels are not as accurate simply because the way the tread is placed.
Tread on 2010 wheels
--ll
--ll
--ll
Tread on Pneumatic wheels
lllll
--ll
--ll
--ll
lllll
With the pneumatic wheels the frisbee can fit under the rubber and still have traction while the 2010 cannot.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 13-01-2013, 23:43
Originally Posted by ksafin View Post
On our side, the 2008 KOP wheel seems to be delivering sad results ... and I'm having trouble figuring out why.
Give more a more detailed description of your prototype and maybe a cause can be identified:
1) linear or curved shooter ?
2) if linear, one or 2 wheels ?
3) what motor(s)
4) what gear ratio
5) what motor voltage, current, and speed ?
6) how much compression ?
7) did you have a cover to prevent axial motion of the frisbee as it is being spun by the wheel ?
8) quantify what you mean by "sad results"
Unread 14-01-2013, 00:02
ksafin's Avatar
AKA: Kirill Safin
3) what motor(s)
4) what gear ratio
I meant 2010 wheels, actually.
1) Linear
2) One
3) CIM
4) Both 1:2.375 and 1:1
5) Don't have the means to check most of those, but it was hooked up directly to a battery and the battery voltage was about 12.75 V
6) Probably around 1/2"
7) No
8) About 15 feet with a max height of around 6/7 feet, or up to 25 feet with a max height of about 4 feet. Can't seem to get a good distance and good height at the same time. Also, it seems to be going rather slow compared to other teams shooters (meaning the velocity of the frisbee as it leaves)
Unread 14-01-2013, 00:06
ksafin's Avatar
AKA: Kirill Safin
I don't have a picture on me right now, but here's a video. Maybe you can deduce something from it.
http://www.youtube.com/watch?v=3fA5k...ature=youtu.be
Our best shot is the last one around 3:15; throughout the video we did various angles and minor adjustments to see varying results.
Unread 14-01-2013, 00:21
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
1) Linear
2) One
3) CIM
7) No
You probably shouldn't expect great performance out of a single wheel on a linear shooter, because that ultimately means you're getting less than an inch of contact area (and thus, acceleration).
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 14-01-2013, 00:30
1) Linear
2) One
3) CIM
7) No
Here are some random thoughts (it's getting late, turning into pumpkin):
Maybe they're out there, but I haven't seen any videos of successful one-wheel linear shooters.
Too bad you don't have any bird's-eye-view shots with a high speed video camera so we could see what the bee is doing as it passes thru. It's probably slipping badly.
Your guide rail is a nice shiny metal surface. It should be grippy in order to get more spin on the bee.
Your wheel speed may be too fast. According to some tests conducted by Team 2073, above a certain wheel speed the exit speed of the bee actually decreases, presumably due to slippage.
Try running the CIM at 10 volts instead of 12, and put some grippy tape on that shiny metal guide rail. I don't think this will get you all the way to where you want to be, but it might be a start.
You're probably going to have to add a second wheel, or go with a curved chute.
If anyone has made a successful one-wheel linear shooter, please tell us how you did it and post a video.
Unread 14-01-2013, 00:41
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Try running the CIM at 10 volts instead of 12.
Why?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 14-01-2013, 00:42
ksafin's Avatar
AKA: Kirill Safin
I should add that our guide rail has a strip of grippy kitchen liner fabric on it.
This serves to prevent the slippage of the frisbee. It seems to work rather well.
Unread 14-01-2013, 00:49
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Originally Posted by Gregor View Post
Why?
To prevent slipping. Slower motor = more time for the bee to grasp
Unread 14-01-2013, 01:16
Gregor's Avatar
Why not gear more?
<Since 2011
Unread 14-01-2013, 01:17
ksafin's Avatar
AKA: Kirill Safin
So then what's the magic ratio?
At what point are you making your wheel too fast that the bee has no time to be accelerated, and at what point are you making it so slow that the bee won't get good spin or speed?
Unread 14-01-2013, 02:40
josesantos's Avatar
josesantos josesantos is offline
Mentor; Former Design Chairman
FRC #0687 (Nerd Herd) (VRC #687z) & FRC #5499 (BHS Robotics)
josesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond repute
*some text removed*
--ll
--ll
--ll
lllll
--ll
--ll
--ll
lllll
Has anyone tried using a thicker (as in tread width, not diameter), non-pneumatic wheel for a shooter? Given that tread placement relative to the frisbee seems to be a major factor, a thicker wheel might work better, right? My team is working on a prototype with the VEXPro traction wheels widened to 2" vs the stock 1", but I was wondering if any other teams have done so already.
Unread 14-01-2013, 09:28
Why?
because:
Unread 14-01-2013, 10:49
Why not gear more?
If you want to do speed control, your CIM voltage at the desired operating point must be less than 12 volts anyway, so that you have some headroom for control.
