Re: convert 2013 frc inventor to 3ds max (2012 edition)
Have you tried exporting .STL files from Inventor? I have done that from SolidWorks, and was able to import .STL into max. If it's a complicated part/assembly use the lowest quality settings to keep the file size reasonable.
I also found this "Tips and tricks on importing Inventor files in 3ds Max.": http://area.autodesk.com/blogs/maxst...els_in_3ds_max |
