Go to Post Failure is not an option. - [more]
Unread 14-01-2013, 11:01
Andrew Lawrence
Posts: n/a
Re: Wheel Types: What's best, and why?
Originally Posted by Gregor View Post
Why not gear more?
The goal trying to be achieved isn't more torque, it's more contact time. A slower wheel will contact the frisbee for longer, and in the end will accelerate the frisbee more.
Tl;Dr: Gearing the motor would work, as it would slow down the wheel, but it's not required since lowering the voltage of the motor is sufficient enough to increase contact time.
Unread 14-01-2013, 11:17
The goal is neither or those. The goal is faster exit speed of the bee.
The higher the acceleration if the bee, the less time it spends in contact with the wheel, and the faster the exit speed will be.
If the exit speed of the bee is slower, chances are it had more contact time, but it spent that time slipping, not accelerating.
Unread 14-01-2013, 11:20
Originally Posted by ksafin View Post
So then what's the magic ratio?
There is no magic. What you are seeking is best determined by prototyping. You can't use someone else's answer, because many factors of the shooter can affect the result.
