Go to Post CAD is the oxygen for engineering. - Bharat Nain [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 06-01-2013, 03:16
Dragonslayerend Dragonslayerend is offline
DuncanDynamics lead programmer
AKA: Tom Xiong
FRC #3970 (DuncanDynamics)
Dragonslayerend will become famous soon enoughDragonslayerend will become famous soon enough
Black Jaguar new Firmware
Hey when does firmware v107 comes out? or do we have to wait till later?
Unread 06-01-2013, 08:54
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
Re: Black Jaguar new Firmware
I saw the firmware download on the IFI website by going to the product page for Jaguars.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 06-01-2013, 09:19
Both bdc-comm and the firmware are installed with the utilities update.
Unread 06-01-2013, 15:05
AKA: Tom Xiong
Thanks, I was looking back at the texas instruments page
Unread 07-01-2013, 00:28
Levansic's Avatar
Levansic Levansic is offline
AKA: Len Evansic
FRC #0585 (Cyber Penguins)
Levansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud of
Has anyone found the release notes, or what changed since v.101?
The FAQ gave no indication of any behavior change, although there was a rumor of removing the current limit.
Unread 14-01-2013, 13:42
AlexBrinister AlexBrinister is offline
AKA: Alex Brinister
FRC #1768 (RoboChiefs)
AlexBrinister will become famous soon enough
We have flashed our Jaguars with the latest firmware (107) but have found that under it, the motor cuts out if it comes under load (after our shooter shoots a frisbee for example). Has anyone else experienced this?
Alex Brinister
Unread 14-01-2013, 14:02
Try this simple solution to see if it helps:
If you are using PWM, you can enable the fixed ramp rate of full reverse to full forward in 1/8 second by placing the limit jumpers parallel to the front of the Jag. See Pages 2-3 of this document.
Unread 14-01-2013, 14:05
That sounds like an overcurrent fault on the Jaguar. If the motor tries to pull more than 40 amps, the Jaguar shuts off its output for a few seconds.
But I thought the current limit was removed from the latest FRC firmware.
Unread 14-01-2013, 17:22
Alan,
You're usually right about such things, but that's news to me.
Where did you hear that?
AKA: Alex Brinister
We do not use PWM.
In our case, the Jaguar shuts off indefinitely (does not come back online after a few seconds). The only way to get it back is to power cycle the control board.
This did not occur with the previous firmware (101). We reverted back to that version but I'm still curious as to why this is happening...
Alex Brinister
Unread 14-01-2013, 17:27
We do not use PWM.
It's available in CAN mode as well, at least it used to be.
But I agree with your desire to understand what's going on rather than just put a band-aid on it.
Do you have access to a scope so you could see what the current is actually doing when the frisbee passes through?
Unread 14-01-2013, 17:40
AKA: Alex Brinister
Yeah, we use the CAN interface and a 2CAN.
Not at the moment, but I will tomorrow. Will post results and observations then.
Alex Brinister
Unread 14-01-2013, 18:52
Levansic's Avatar
AKA: Len Evansic
If I recall correctly, there was a very quick mention about the current limit being removed as part of the announcement of IFI taking over the production of the Jaguar. That's why I am very keen on finding the release notes for what changed between v. 101 and v. 107.
Unread 14-01-2013, 19:37
http://www.usfirst.org/roboticsprogr.../blog-10-03-12
Second, the firmware will be modified to remove the current limit protection (this is for black Jaguars only and will not apply to the grey Jaguars).
More discussion here: http://www.chiefdelphi.com/forums/sh...50#post1188950 see post 13
Unread 14-01-2013, 19:56
Originally Posted by Joe Ross View Post
Thanks Joe.
I had read the CD thread (and post) you linked to, but not blog. I had the impression that the current limit was modified to improve perceived robustness, but not eliminated entirely. Time will tell I guess.
