Disc Lauching Velocity
We're looking to find the exiting velocity of a disc from a launcher. Please provide the basis for your calculation. Thanks~!
From MOE 365 |
Re: Disc Lauching Velocity
Its a dynamics problem but the calculations can change based on how your device is set up. A description of your shooter should be enough to figure out the equations and what variables you'll need to plug in though.
Re: Disc Launching Velocity
Thanks. |
Measuring B velocity and wheel RPM this weekend. Will post results
It would be a service to the CD community. |
Here is a neat device that can help you out with your velocity numbers.
http://www.bhphotovideo.com/bnh/cont...G&A=details&Q= I good video analysis program is UberSense on a Ipad or Iphone http://www.ubersense.com/ Last edited by roystur44 : 11-01-2013 at 15:35. |
#7
This does not give you the "muzzle" velocity, but it does give you the average velocity, and you know you should probably target faster than that at the muzzle. If you simultaneously take times at teh 25' mark, then you will have the average velocity for that distance as well, and you can use the 3 points to see the trend for speed (total time give total average velocty, timing at 25' mark allows for 25' average as well as the 25-50 foot average by subtracting the two. |
#8
I have an Arduino Sketch that you are free to use to create a Chronometer. All you need is a couple of sensors to attach that can sense when the disk passes. You may have to change the Interrupt type from "RISING" to "FALLING" depending on the sensors you use.
Just edit the distance value in the code to match the separation distance between the sensors and it will spit out the velocity in ft/sec whenever the two sensors are triggered by a passing object. Code:
* This Sketch is for a Chronometer that uses the "micros" function to capture two points in*
* time and determines how much time has elapsed between them in microseconds. By knowing *
* the distance between the to sensors, the velocity of the object can be determined. *
* Bill Kendall, Jan. 11, 2013 *
#define SENSOR_DIST 6 //This value is the distance between the sensors in inches
unsigned long event1 = 0; // value in 'micros" at the time of this first trigger
unsigned long event2 = 0; // value in 'micros" at the time of this second trigger
int calculate = 0; // If set to 1, a calculation and display of the velocity will occur
unsigned long duration = 0; // Amount of elapsed time between events
unsigned long velocity = 0;
void setup (void)
attachInterrupt (0, ISR0, RISING); // Interupt 0 (pin 2) calls "ISR0" Thie is the first trigger
attachInterrupt (1, ISR1, RISING); // Interupt 1 (pin 3) calls "ISR1" This is the second trigger
Serial.begin(115200); // connect to the serial port
void ISR0 (void)
event1 = micros(); // record the microseconds counter
void ISR1 (void)
event2 = micros(); // record the microseconds counter
calculate = 1; // Allow the velocity calculation code to run.
void loop (void)
if (calculate != 0);
RunMath ();
void RunMath (void)
duration = (event2 - event1); // elapsed time between triggers in u seconds
velocity = ((SENSOR_DIST/duration)/12)*1000000; // Calculate velocity in feet per second
Serial.print("The projectile is moving at ");
Serial.print(velocity);
Serial.println(" ft./sec.");
calculate = 0;
#9
You can see a video of our shooter here; http://www.youtube.com/watch?v=ThZCOtjVJmw |
#11
I've "refined" my Chronometer sketch (read that as "I now have it working correctly"). After testing it, I found it wasn't quite what I wanted, so I fixed it.
Please enjoy! Code:
float SENSOR_DIST = 6; //This value is the distance between the sensors in inches
float distance;
int firstint = 0; //Set to 1 if Interrupt 0 has occurred
float velocity = 0;
void setup (void)
attachInterrupt (0, ISR0, FALLING); // Interupt 0 (pin 2) calls "ISR0" Thie is the first trigger
attachInterrupt (1, ISR1, FALLING); // Interupt 1 (pin 3) calls "ISR1" This is the second trigger
distance = (SENSOR_DIST/12.0); // Convert sensor spacing to feet
void ISR0 (void)
firstint = 1;
void ISR1 (void)
calculate = 1;
void loop (void)
if (calculate == 1 && firstint == 1)
RunMath ();
delay (500);
void RunMath (void)
velocity = (((distance)*1000000)/(duration)); // Calculate velocity in feet per second
Serial.print (velocity,2);
calculate = 0;
firstint = 0;
#12
With our latest shooter setup, we measured frisbee exit velocity very roughly with a 60fps camera as well as launch surface speed (under no load) with an optical tachometer. When making 3pters from 30" directly above the auto line, we measured an exit speed of roughly 2400 ft/min (+/- a few hundred), with the launch surface going about 6000 ft/min under no load (one-sided with no noticable slip, so you can see there is some spin down in our implementation, but it spun back up within a second). These numbers are lower than we had previously been estimating, but hey that's why we test.
#13
Would you please describe your latest shooter setup, to give some context to the numbers you posted.
There is a nice software package for the I phone. "Vernier Physics."
Take a video of the frisbee launching past some landmarks of known separation, mark those spots, and you can get the time in between. |
#15
We had about 12in of contact with the belt. To measure exit velocity, we took several 60fps videos of the launch, and measured a 4ft travel out of the shooter in 6 or 7 frames, averaging about 2400 ft/min. The low frame count of course makes the uncertainty on this figure substantial (about 300ft/min per measurement, 100ft/min over 10 measurements). |
