Go to Post In the end any amount of time can work, just be smart about how you use it. - Jay O'Donnell [more]
Unread 12-01-2013, 15:56
EskimoToast EskimoToast is offline
FRC #1710
EskimoToast is an unknown quantity at this point
Camera Problems
Once upon a time... Our camera is not working. We can edit the fps. We can also edit the compression. The camera is indeed on. The code is totally loaded. Like we can do everything except see the vision of the camera. There is no lens cap.
But in all seriousness, our camera isn't working.
Unread 12-01-2013, 17:57
Re: Camera Problems
Did you use the Camera tool to set it up?
Can you get to it using a web browser (if you have not set the camera up: 192.168.0.50) (or 10.17.10.11 if you have used the Camera tool) ?
Unread 12-01-2013, 18:13
Derschatten Derschatten is offline
FRC #1203 (Pandemonium)
Derschatten is an unknown quantity at this point
Re: Camera Problems
If you can get in via the web panel. Is that stream video?
Unread 12-01-2013, 18:15
Re: Camera Problems
You can view the video stream in the browser.
Unread 12-01-2013, 18:26
Blackphantom91's Avatar
Blackphantom91 Blackphantom91 is offline
Mentor + 4 = Stuck For Life
AKA: Malcolm Stirckland
FRC #1986 (Team Titanium)
Blackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura about
Re: Camera Problems
Make sure the camera is setup through the axis tool. also make sure you are using the right cables if you are talking though the robot you just need a strait though, or if using pc use a crossover.
[img*]http://i.imgur.com/Os2oTET.jpg[/img*]
Unread 13-01-2013, 00:06
Re: Camera Problems
The other way around.
PC's don't required cross-over cables. but the cRIO/camera direct connection does.
Unread 13-01-2013, 00:14
bhumudar's Avatar
bhumudar bhumudar is offline
Mentor/Programming/Electrical
AKA: Bryant Humud-Arboleda
FRC #0714 (Panthera)
bhumudar is on a distinguished road
Re: Camera Problems
If you are using LabVIEW, make sure that your vision enable button is on in the front panel of the robot main.
Stevens Institute of Technology
B.A - Electrical Engineering 14'
Mentor - FRC 714 (2012-Present)
Student - FRC 714 (2009-2010)
2013 Bridgewater-Raritan Winners (Thanks 1676 & 3314)
2012 MAR Regional Championship Judges Award
2012 Mount Olive District Excellence in Engineering Award
2012 Chesapeake Regional Finalist (Thanks 2068 & 358)
2012 Hatsboro-Horsham District Gracious Professionalism Award
Unread 13-01-2013, 19:51
stingray27's Avatar
stingray27 stingray27 is offline
AKA: Michael Ray
FRC #0027 (Team RUSH)
stingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to all
Re: Camera Problems
Another thing (And trust me, it may sound stupid but we have done it before). When you connect to the robot through tether, put the tether in the router, not the cRio. We once put it in the cRio and couldnt figure out why we werent getting camera feed. Well the camera was plugged into the router and our laptop wasnt connected to our router....
Michael Ray
Team RUSH 27
Driving Record: 93-64-0 Best Finish: Finalist (x4 FiM Districts)
Coaching Record: 16-7-0 Best Finish: Winner (Kettering Invitationa)l
Unread 13-01-2013, 22:29
ktrobotcreator's Avatar
ktrobotcreator ktrobotcreator is offline
Programmer
FRC #1245 (Shazbots)
ktrobotcreator is an unknown quantity at this point
Re: Camera Problems
What Dashboard are you using? The LabView one? A version of SmartDashboard?
And just to make sure, the green light on the front of the camera is lit, right? It's not orange? It should be since you can view it in a broswer, but I just want to make sure.
Unread 13-01-2013, 22:46
Keyreaper's Avatar
Keyreaper Keyreaper is offline
Keyreaper
AKA: Cyrus Duong
FRC #1710 (Revolution Ravonics)
Keyreaper is an unknown quantity at this point
Re: Camera Problems
Thanks for all the helpful responses guys. We eventually got it working by restarting his laptop. He had done the updates for DS and LabView but didn't restart. Such a simple thing too. Sorry for the trouble.
CTO/Head Programmer of Team 1710
Unread 14-01-2013, 11:15
cjlane1138 cjlane1138 is offline
Team 1138
FRC #1138 (Eagle Engineering)
cjlane1138 is an unknown quantity at this point
Re: Camera Problems
If it doesn't work, restart the computer. If it still doesn't work, ask on ChiefDelphi. haha
Eagle Engineering 1138
Unread 14-01-2013, 14:57
splatter's Avatar
splatter splatter is offline
Cant Spell Robots With Out Rob
AKA: Robert
FRC #0271 (Mechanical Marauders)
Team Role: CAD
splatter will become famous soon enough
Re: Camera Problems
A cross over is not required to connect the camera to the new wireless bridge a regular cat 5 for example will do fine. Also make sure your wireless bridge is in the 2.4ghz AP mode.
FIRST Team 271
<Electrical, CAD>
http://www2.bayshoreschools.org/robotics/
