Re: What kind of shooter is your team using?
Hmm, well we measured our belt and curved shooters at some 25deg up and flat. Maybe I will see if anyone is up for the task of testing a linear wheel shooter, but let me guess, you used pneumatic wheels right?
Yes (Well, psudo-pneumatic) Having the wheels flex makes a big difference. From "not working at all" to "works great". My measurements were from 3 ft off the ground at 0 degrees
Yea, I have been pressuring our mentor to get those wheels but for some reason he cant. But I think we may see a fix by adding some stiff rubber tubing(or whatever works) to the outer wall instead of having the wheel.
We are planning on a 2 wheel linear shooter with pneumatic wheels. Essentially the robot in 3 days shooter, except harder and faster. Ideally the disk will come out at about 25-30 m/s.
We don't know for sure, but today we got our 3rd or 4th iteration of the prototype working, with a curved shooter going thru about 90 degrees, with a 6" wedgetop tread wheel driven by a CIM and geared up in speed about 30%. It shot around 30 feet to about 6ft height (shooter on the ground), shooter angled up maybe 15 degrees. I think we'll probably go with this, the neat thing is with the way the thing is set up with sprockets and chain, we can change the ratio to get about any speed we want from 2000 to 8000 rpm or so at the wheel.
We are doing basically the same thing. So far, it's working great, and shoots very far (not sure of exact measurements)
#7
None.
#8
